Radiator Leak
Old Mar 20, 2016 | 06:40 PM
02GoldVette's Avatar
02GoldVette
Default Radiator Leak
So I've noticed that my 02 Auto Vette is leaking antifreeze. At first I noticed a couple of drops and over time, I've noticed a decrease in the radiator container. So my question is, what can I do to fix it? I'm thinking of using Bar's Stop Leak. Anyone have any experience with this product?
P.S. Very small drop, so no giant leak, but decreased levels over maybe 6 month period.
Was able to take some pics. These are from the front passenger side close to the wheel below the antifreeze tank
Old Mar 20, 2016 | 07:01 PM
grantv's Avatar
grantv
I had a small leak in a car many years ago. I tried this product; it didn't fix the leak but it did plug something else up in the cooling system (can't recall exactly, long time ago).
I'm a much better mechanic now, and the more capable I become, the less I can fathom the idea of using quick fixes.
Old Mar 20, 2016 | 07:11 PM
Rob 02's Avatar
Rob 02
Radiators and hoses are fairly inexpensive if you shop around. Stop leak can lead to bigger problems down the road (as the former poster said). It could clog sensors.
When these quick fixes fail, it tends to happen in the worst possible places and times costing even more money.
Old Mar 20, 2016 | 07:21 PM
Smoken1's Avatar
Smoken1
Had the same in my 02. Water pump was starting to leak. Please don't try the stop leak garbage
Old Mar 20, 2016 | 07:55 PM
vettenuts's Avatar
vettenuts
You first need to isolate where the leak is. My first thought is water pump and second would be radiator.
Agree with other posters on the stop leak, unless you are looking for bigger problems.
Old Mar 21, 2016 | 02:21 AM
02GoldVette
Thanks for the input guys. Getting 0 for 5 is more than enough input than I need. I'll continue to look for the cause and take it to a shop for the proper fix.
Old Mar 21, 2016 | 07:48 AM
vettenuts's Avatar
vettenuts
Find the leak, it may be a simple fix not requiring a shop. If its a tank or hose it is pretty easy. Water pump is easy as well, but if you don't typically work on the car might be best left to a shop. Most of the time it is something simple that is the cause.
Old Mar 22, 2016 | 01:39 AM
02GoldVette
Considering that if it were to be a hose replacement, where would you recommend getting a new hose from?
Old Mar 22, 2016 | 04:03 AM
strand rider's Avatar
strand rider
I got a top hose from pep boys, because it was Sunday, or I would have gone to the dealer.
I was surprised they had one in stock. i think the hose was clamped off when I had the radiator replaced, and it tore the hose. Hecho in Mexico for the pep boys hose.
I mention it because my radiator failed up on top , the plastic section there often fails, but not as often as the overflow tank hose nipples. A couple of common places to look.
strand rider
Old Mar 23, 2016 | 12:26 AM
BigGun's Avatar
BigGun
Anywhere except the dealer unless you want to pay 3 or 4 times as much. Nothing special about a radiator hose.
Old Mar 23, 2016 | 02:59 AM
Rob 02's Avatar
Rob 02
^I agree. I buy affordable ones and replace them when they are old.
The rot occurs on the inside where you cant see. The old ones can be rotten on the inside and look new on the outside. You can probably get both rad hoses for less than $35. There are two heater hoses that stream coolant as well. If they are original hoses then they are probably due.
Old Mar 27, 2016 | 10:44 PM
02GoldVette
From the looks of it, I don't think it looks like a rubber house leak. What you guys think?
Old Mar 28, 2016 | 07:34 AM
vettenuts's Avatar
vettenuts
There are also two heater hose connections to the water pump in this vicinity. I would wipe the area dry as best as possible and then see where the leak comes from. You can also do a pressure test.
Old Mar 28, 2016 | 01:38 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
The plastic overflow tank is a common source of leaks.
Mine just let go on my 98 last month.
Got a new tank and hoses for under $100 - very easy repair.
Mine cracked at the fitting on the bottom of the tank. It would actually spray antifreeze when I pushed and pulled on the hoses.
Old Mar 28, 2016 | 03:04 PM
Drewster67's Avatar
Drewster67
If it were me I would replace the radiator, upper and lower radiator hoses and water pump while you are doing this repair.
OEM New Radiator is about 198.00
OEM New Hoses is about 40.00
OEM waterpump replacement is about 140.00 (Lifetime warranty)
Im actually going down this road along while replacing my oil pump - Finally happening this week after one delay after another.
YMMV
Dont ever use stop leak in your car ... my .02
Old Mar 29, 2016 | 04:54 PM
123Gone's Avatar
123Gone
Yep, replaced mine last night. Bought a Dorman replacement off of Amazon for $54. 30 to 45 minute fix.
To Radiator Leak
