Ceramic coating headers and?
Old Mar 26, 2016 | 12:04 PM
Grizvette's Avatar
Grizvette
Default Ceramic coating headers and?
I was thinking of ceramic coating headers and the rest of exhaust at least down to the axlebacks. Is this overkill or would it also help with floor pan heat dissipation or waist of money?
Old Mar 26, 2016 | 06:29 PM
LoneStarFRC's Avatar
LoneStarFRC
Ceramic coat headers and ceramic coated Elite Engineering tunnel plate WITH Thermal Abs option, FTW.
Old Mar 26, 2016 | 07:09 PM
Grizvette's Avatar
Grizvette
Never knew about this option. I guy gets fixed on a plan of attack and never looks at other scenarios. Thank you!
Old Mar 26, 2016 | 07:59 PM
StingrayRebel's Avatar
StingrayRebel
if you can afford to have the whole system ceramic coated it is not a bad thing to do... at minimum do the headers and elite tunnel plate... if you coat the midpipe that will further help with keeping the console cooler and if you coat the rear section that can help keep trans/diff fluid temps down from the decrease in radiant heat transfered from the exhaust
Old Mar 26, 2016 | 09:13 PM
tbrowne's Avatar
tbrowne
It can't hurt but it might be just a little bit over kill. Coating the headers does help under hood temps. The rest of the system gets a good amount of air passed over it as long as the car is moving. It's your call in the end but few go to the expense of doing the whole system.
Old Mar 26, 2016 | 10:49 PM
Last C5's Avatar
Last C5
It's a great idea. It keeps the heat down in cab quite a bit and if your cat backs have separate over the axel pipes do those too to help with the tranny and diff heat. Second benefit is how good the system looks even after a few years of use.
Old Mar 27, 2016 | 07:59 AM
dankhts's Avatar
dankhts
My long tubes and mid pipes are completely coated (except cats) to the axle back, a bit less heat through the floor and still looks like new after 6 years
Old Mar 27, 2016 | 02:56 PM
Mickeyrx70's Avatar
Mickeyrx70
This is what I did along with the Elite Engineering Tunnel Plate with Thermal ABS. There's no heat issue at all.
Old Mar 27, 2016 | 10:07 PM
Grizvette's Avatar
Grizvette
Thanks for all your opinions and ideas greatly appreciated.
To Ceramic coating headers and?
