Does anyone out there have any experience with the little light that is attached to the underside of the hood? Mine did not light up, so I replaced the bulb with a Sylvania 211-2LL as recommended and still no light. What am I missing?
The connector for that light (where it connects to the cars harness) is on the front passengers side of the radiator shroud about 8" down from the top. Its a small 2 way water tight connector. Make sure that its properly connected.
I would also check the fuse for that circuit.
Thanks, Bill. You nailed it!!!! It now works.
DILLI1
In general, my dealer service department disconnects the light when they will be under the hood for any amount of time. Sometimes they forget to reconnect it.
