LS3 max power
Old Mar 31, 2016 | 07:05 PM
red88L98convert's Avatar
red88L98convert
Default LS3 max power
I'm going to build an LS3 for my FRC. I am going to be going with all new parts including the block. My question is, what is the max power level for a stock LS3 block. I'm going N/A, but may spray occasionally, depending on the strength of the block.
Tia
Old Mar 31, 2016 | 07:37 PM
ZZ06's Avatar
ZZ06
All or none huh? Well, if you don't mind me asking, what is the purpose for the car? MAX power can seem straight forward, but in all reality with different driving styles, coupled with track use its become relative term. If you truly want MAX power than ive had a few buddies run anywhere from 800rw to 1000+ on boost with a LS3 block. That more so depends on the rotating assembly used, so on and so forth. But you said N/A so unless your gona spray a 2 stage with a **** of nitrous, your block will be fine. Its the pistons that take the punishment. I have a N/A TSP 418ci in my own. I didn't quite have the money for the heads of choice so am 490/486 to the ground with a mildish bump stick. In due time, I will have a set of Trick Flow 235's and shoot closer to 520-530 and be decent in drivability. This kinda goes without saying, a MAX effort build takes methodical research,even more so DEEP pockets. My build, to include installation, was over 11k. This is with me already having headers, exhaust and a clutch. Ima let the tranny ride out as long as she can.
Old Mar 31, 2016 | 08:37 PM
Nitrous Express & Snow Performance's Avatar
Supporting Vendor
They can take a beating. Let me know if you need a kit. I'd be happy to help.
Old Mar 31, 2016 | 08:51 PM
red88L98convert
Well, I'm not trying to make max power, I'm trying to find the limit of the block so that I don't blow it up. I just read an article in the latest Vette magazine where they built a 415 with 576 hp and 566 tq. That's essentially what I want to do. Eagle rotating assembly, trick flow heads....pretty basic stuff.
Old Mar 31, 2016 | 08:52 PM
red88L98convert
I've already got a bottle.....
Old Mar 31, 2016 | 09:29 PM
ZZ06's Avatar
ZZ06
Was that an engine dyno? If not, I wouldn't call that "basic" stuff, or rather CHEAP stuff. If those numbers are engine dyno numbers than its roughly close to what I made. maybe a few more on the high end. With that power you could spray a 300 shot on her and it will run all day, obviously proper tuning. Depending how OFTEN you went thru a bottle, I wouldn't look for longevity out of it. Nitrous pistons or not, its HELL on a motor. My old tuner 5-6 years ago had a 418 and made 550/53X with a 2 stage 300 shot that made almost 900rw and cut a 1.5X and ran 9.81 at 144. He had to tear it down for rebuild around 40-50k. Needless to say, he is HARD on motors. For someone playing in spraying the streets (pending how large of a shot), id like to think you could at least double the miles.
Old Apr 1, 2016 | 10:32 AM
red88L98convert
Yeah, those were dyno numbers. I say basic, because it's a street type build....no block filler, no complex valvetrain, girdles, etc. From what I've read the ls3 is a very strong block and like I had initially said, I am not trying to make max power, I just want to know what they can handle. If they can handle 900 boosted hp, then 600hp should live quite a while and give me piece of mind.
Old Apr 1, 2016 | 11:29 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Tia
You don't have to worry about the block strength on the LS3. We have a F1A 416 CID making 907 RWHP and ran 9.59 @ 146. It has forged rotating assembly and studed. You should be fine running NA.
__________________
Old Apr 1, 2016 | 01:00 PM
ZZ06's Avatar
ZZ06
The block will take that all day long smiling. You spraying nitrous, id be more concerned about the rotating assembly and less worried about the block.
Old Apr 1, 2016 | 04:16 PM
red88L98convert
Thanks guys, that was all I needed to know. I was actually thinking about going with an LSX block, just for the strength. Now I'm not worried about reliability or the extra weight.
Old Apr 2, 2016 | 12:25 PM
95wht6spd's Avatar
95wht6spd
Check out the long thread on the LS3 in the road race and autox section if you want more info.
To LS3 max power
