Catch Can Conundrum! Please help.
Old Apr 1, 2016 | 02:59 AM
Lpe403's Avatar
Lpe403
Default Catch Can Conundrum! Please help.
So, I notice the top of my catch can isn't tight, but when I screw it on tight (both the cap and nozzle), the top nozzle is pointing the opposite direction of where I want it to go.
Here's the way I want it, but the top is loose.
When I tighten the top, the nozzle points away from where I want it go:
From the top:
What can I do about this? Note that the side port is where I want it to be.
Old Apr 1, 2016 | 06:30 AM
ZigZag's Avatar
ZigZag
You can try wrapping the threads in teflon tape. It should take up some space so to speak and you can come up shorter when screwing it in and may line up where you want it. Hope that made sense.
Old Apr 1, 2016 | 08:49 AM
StuntHeavy's Avatar
StuntHeavy
If Teflon doesn't work, a washer may (similar to how you index spark plugs)
Old Apr 1, 2016 | 01:29 PM
ZZ06's Avatar
ZZ06
Yup I was just about to say try the Teflon. I have it on mine.
Old Apr 1, 2016 | 04:01 PM
Lpe403's Avatar
Lpe403
Thanks guys!
Old Apr 2, 2016 | 09:26 PM
Dave68's Avatar
Dave68
I assume your connector has tapered threads (NPT). If so, you can use non-curing pipe sealant that doesn't require that the connector be super-tight. The disadvantage of using Teflon tape is that the connector to which the tape is applied DOES need to be somewhat tight, which can limit where the opening is facing.
To Catch Can Conundrum! Please help.
