parking light issue
Old Apr 10, 2016 | 09:15 PM
theoldmusicman's Avatar
theoldmusicman
Default parking light issue
Having a problem with my right front parking light. It doesn't work. Blinker works, running light works, but no parking light. I'm guessing the parking light is on a different circuit from the blinker/drl. Good ground since since the other lights work in that socket. The lights all work fine on all the other corners of the car so the fuse must be good. Not getting any voltage on the middle wire to the right front socket. Yes I have switched out the bulb with a known working one. I think the next step would be to trace the wire back through the next up-line connector and see if I have voltage there. Unless someone can tell me where else to look?
Old Apr 10, 2016 | 10:08 PM
theoldmusicman
Originally Posted by 8VETTE7
Looks like your car is a 97. Not sure if wiring for the parking/turn/driving lights are the same as on the later years or not. I can post the wiring diagram from my 04 shop manual if you want it......
I'm thinking the wiring is probably the same, but I'm not sure myself. That would be great if you could post that diagram. I could print it off and check it out tomorrow. Thanks!
Old Apr 11, 2016 | 06:07 AM
dadaroo's Avatar
dadaroo
All years are the same.
Mr. Sam
Old Apr 12, 2016 | 04:09 AM
LWSZ06's Avatar
LWSZ06
Here the schem for an 04:
Larry
To parking light issue
