First off, I have tried to search and found lots of good info. My car blows only cold on the passenger side (too cold to test AC), and I find the codes B0365 and B0367. Both are H(istory) codes by the way. When I have the ignition on and motor off, I can hear a humming/grinding noise continously. I have read about clearing the codes and to pull fuse nr 27. But can I assume that the actuator is shot since I hear the grinding noice, or is it worth a try with the fuse pulling? How will ut be when I want to use the AC in the summer, will the passenger side still blow outside temp, and driver side cold?
Another thing is that it seems like the HVAC fan speed is not working properly. If I try to operate the fan speed manually, it seems like there is no change when I press the + button. When the fan speed indicator is on top and I continue to press +, suddenly the fan goes on full. In manual mode it does not seem to change speeds. I have the dual electronic type...
Thanks for the patience with this topic
