Dyno results question
Old Apr 22, 2016 | 03:15 PM
C5stroker's Avatar
C5stroker
Default Dyno results question
Got a 2000 c5 with a 402stroker based ls2 titanium rods diamond pistons 80m injectors lingelfeter fuel pump l92 ported milled heads by Texas speed msd ignition wires plugs, rpm stage 6 trans c6z rear end 3000 stall and a mean cam. The past owner gave me a dyno sheet of 444whp 422wtq on a mustang dyno. Apparently a "extremely" conservative tune and the tuner claims 18% Lower then the Dynojet that is near me which is why he referred to it as a heartbreak dyno. I have no local mustang dyno so I dont know how those read I only have dynojets. So I should be popping out to mid 500 wheel horse with this car if that's the case correct? Any expierence from mustang dyno readings to a dyno jet?
Old Apr 22, 2016 | 03:31 PM
enoniam's Avatar
enoniam
I believe I've read in the past that mustangs read about 10% below dynojets.
That said I got 383 out of my heads/cam/intake/lt headers/exhaust A4 car on a mustang!
