LS1 Spark Plug Help
Old Apr 27, 2016 | 04:02 PM
Costanza's Avatar
Costanza
Default LS1 Spark Plug Help
Hello All:
First, let me say thank for you allowing me in the forum. Took ownership of my first Vette a few days ago (99 Coupe, 6-Speed Manual) and I already find this site a great help.
My question is about plugs. Due to multiple owners prior to me, I don't know how long the plugs have been in and I'd like to change them. Also, I have know idea if the guy before did it right (i.e., anti-seize). In trying to free the first plug, I found it to be quite tight...so I stopped. I feared breaking it or backing out the threads if I went with too much torque to the ratchet handle. . Right now I am hitting the plugs with PB Blaster and letting them sit before trying again. I tried while engine was cold.
Any advice on removing plugs from these heads if they are somewhat stuck.
Thanks!
Old Apr 27, 2016 | 04:27 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
First Congrats and welcome (I also have a 99 six speed coupe) the engine needs to be cold, I have no idea what is tight to you but sometimes they can be very difficult and it is better to stop and think about it as you have done !!!! Letting them soak is not bad, I just don't know if it can get where it will do some good ??? Try going back and forth even if you don't think they are moving ??? Worse case you break them and pull the heads and put some better ones on with a new cam and headers ???? LOL
Old Apr 27, 2016 | 04:30 PM
Costanza's Avatar
Costanza
Default How much is too much.....
Thanks AKA....I know. It is hard to judge how much force is too much. I only used the standard size ratchet handle. I was afraid the breaker bar would be too much force. Ugh....maybe I should save the plug change until the winter season when she can sit in my garage for few months and I can drive her anyway (New England....)
Old Apr 27, 2016 | 04:44 PM
Costanza's Avatar
Costanza
Default Also............
I read in another thread somewhere with respect to the potential for breaking plugs or stripping threads that "it almost never happens"...therefore use the force. I am skeptical. Thoughts appreciated.
Old Apr 27, 2016 | 04:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I doubt PB Blaster will be able to soak in because the plug base seals against the head.
Just MAKE SURE that you are actually turning the plug to the LEFT!
Like AKA recommended, turn left and then a little right. Once you break the head to plug seal, it should come out pretty easy.
I would not be afraid to use a little longer ratchet or breaker bar. There either going to break loose and come out easy or there going to rip the threads out.
If you are really worried and afraid that there STUCK, you can get a torch and warm up the area AROUND the plug to about 150 deg (NOT THE PLUG) and see if that helps.
WIRES. If you are not sure of the spark wire condition or if you damaged them, I highly recommend the GM RED Performance wires as a replacement wire.
Replace the plugs with GM AC Delco Iridium plugs.
Use a little bit of silver antiseize on the new plug threads and use DIELECTRIC GREASE inside the plug boots.
Bill C
Old Apr 27, 2016 | 04:58 PM
Costanza's Avatar
Costanza
Default Thanks.....
Bill C
Hello Bill, thanks for the advice. I already purchased plugs, but I bought Denso iridium plugs.... Re: the wires, they appear to be in decent shape, but I have some on order from Jegs (MSD wires). The coils appear to be stock GM coils which I hear good things about.
Old Apr 27, 2016 | 05:45 PM
Costanza's Avatar
Costanza
Bill C
Bill, I was thinking over your advice re: the torch to heat the area to 150 degrees.....any reason why running the engine briefly to get some heat in the motor wouldn't accomplish the same? Thanks.
Old Apr 27, 2016 | 05:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES!!! When you run the engine you heat up the PLUG AND the HEAD. If you have a STUCK Plug and heat the head around the plug, the aluminum around the plug will expand a very slight amount and have less grip on the plug threads.
BC
Old Apr 27, 2016 | 07:57 PM
twokbolt's Avatar
twokbolt
I just changed plugs on my car. It all started when I went to CHECK a plug and the thing was in so tight it snapped in half when I tried to remove it. I snapped a total of 3 off at the insulator base. Mind you I was using a spark plug socket too. It wasn't a huge issue since the socket could still get around the plug and get the bottom part out. Torque on the plugs is only supposed to be 11 ft lb and yes use anti seize putting the new ones in and die electric grease on the boots. Unfortunately a gorilla was the previous owner of my car.
Old Apr 27, 2016 | 08:32 PM
Costanza's Avatar
Costanza
Twok....any damage to threads when you horsed on the breaker to get them out?
Old Apr 27, 2016 | 08:49 PM
ZigZag's Avatar
ZigZag
Hello, and where are you in N.E. ? You can put that in your profile so we know where your from. As others have mentioned you may need to use more arm strong than you'd like. I changed my plugs and wires at 121,000 miles and they must have been original.
For one the wires wouldn't even come off. I destroyed or cut 5 of them to get them out of the way. Then the plugs were in so tight I had to take a bunch of steroids to get up the strength to break them loose. Finally got them out after two hours but everything went in fine and the car purred like a kitten since. Anti-sieze is your friend.
Tom
Old Apr 28, 2016 | 01:00 AM
My Vette Life's Avatar
My Vette Life
Hello All:
Thanks!
I did a video on removal and installation on drivers side, passenger coming soon and also with denso plugs.
Old Apr 28, 2016 | 07:13 PM
twokbolt's Avatar
twokbolt
No damage to the threads. I was using a ratchet not a breaker. Although a breaker probably would have helped.
Old May 18, 2016 | 04:12 PM
Costanza's Avatar
Costanza
Just a quick followup AKA...I finally got around to doing this and your advice helped. A slightly bigger bar and easy rock tight and loose and they popped right out! I think it was mainly fear holding me back....fear of breaking one off!
Old May 18, 2016 | 08:50 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
hope you Anti-Seized the new ones ???
Old May 18, 2016 | 10:38 PM
Costanza's Avatar
Costanza
Yes! Anti-seized and ready to roll.
Old May 19, 2016 | 09:06 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Did you use a torque wrench, when you installed the new ones?
To LS1 Spark Plug Help
Old May 19, 2016 | 03:37 PM
Costanza's Avatar
Costanza
Yep
Old May 19, 2016 | 06:35 PM
leadfoot4's Avatar
leadfoot4
Yep
Old May 20, 2016 | 12:01 PM
stevebz06's Avatar
stevebz06
I have been told to never try to remove plugs from a hot engine. It should be cold.
Try the PB Blaster or WD40 trick. It worked for me. The oil easily
penetrated the threads and made removal a breeze.
