Which Fuel Injectors?
Old Apr 27, 2016 | 05:05 PM
digmyvette's Avatar
digmyvette
Default Which Fuel Injectors?
Would someone please shed some light on why there are different size fuel injectors? I see for the LS1 it's 43 psi, but why a 34# or 60# and so on? How do you properly size them for your application?
Old Apr 27, 2016 | 05:46 PM
mmartinez's Avatar
mmartinez
Default Fuel injectors
The higher numbered fuel injectors will allow more fuel for your application, if you have headers, high performance cam and heads, maybe turbo, or supercharger. The number has nothing to do psi, you want to avoid to high an injector duty cycle when tuning an engine so you install higher capacity fuel injectors.
Old Apr 28, 2016 | 07:55 AM
digmyvette's Avatar
digmyvette
Okay, that makes since, but how do you determine proper size? I presume there is a formula?
Thank you mmartinez for your help!!
Old Apr 28, 2016 | 09:04 AM
feeder82's Avatar
feeder82
Heres a link, to shed some light
http://fuelinjectorclinic.com/flow-calculator
Old Apr 28, 2016 | 01:07 PM
digmyvette's Avatar
digmyvette
Thank you sooo much. A quick (well, maybe not so quick ) lesson can be found in this link. I highly recommend it to anyone with sleep empathy!
Old Apr 28, 2016 | 02:26 PM
enoniam's Avatar
enoniam
digmyvette,
I saw your plans on the thread where you were looking for help with a vibration issue. The cam you mentioned there was one that Comp recommended to me last summer when I was rebuilding my engine as it was similar to the trashed cam that I pulled out of the engine. I noted that I wanted to give up a little on the low end for some more on the top and they recommended their 54-428-11 cam with basically more duration than what you are looking it. Engine also has the Weiand/Lingenfelter intake manifold, long-tube headers, x-pipe, Corsa Indy exhaust, and ported and slightly milled 243 heads. I put 42# injectors on that setup which seems to have been the correct choice.
Old Apr 28, 2016 | 04:02 PM
digmyvette's Avatar
digmyvette
Originally Posted by enoniam
digmyvette,
Thank you, thats good to know!
Old Apr 28, 2016 | 04:55 PM
feeder82's Avatar
feeder82
Ahh posted the link from my phone in my last post never copies right here's the working link
Old Apr 28, 2016 | 05:12 PM
Smoken1's Avatar
Smoken1
By those calculations I guess I went over kill to get to mid 700's
Old Apr 29, 2016 | 07:00 AM
digmyvette's Avatar
digmyvette
Wow! Thats simple. I spent several hours, a ream of paper and several pencils working this out last night! LOL
To Which Fuel Injectors?
