Help with ATI procharger!!!
Old Sep 6, 2002 | 03:21 AM
Cartier1's Avatar
Cartier1
Default Help with ATI procharger!!!
Hi!
does anyone knows why my boost gauge is ponting at -15 press??
whe i push to full throttle it ponts on 0!
it connected to the intake manifold vacuum port its that right???
ok thanks everybody for your help!! :cheers:
Old Sep 6, 2002 | 10:58 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: Help with ATI procharger!!! (Cartier1)
Is it making power? Sounds like the surge valve is open or a hose is off and you're not making boost. Those numbers are indicative of a naturally aspirated car.
Old Sep 6, 2002 | 02:43 PM
Cartier1's Avatar
Cartier1
Default Re: Help with ATI procharger!!! (Andy@AandACorvette)
yeap sounds how its making power and it feels its a brand new,what else may i check to see if its working ok ????????? :crazy: :crazy:
Old Sep 6, 2002 | 03:11 PM
Red5's Avatar
Red5
You have a tube off. Your blowing your boost out somewhere. Get used to this.. I dealt with it for years. Make it a point to have a scew driver and the small socket drive and plenty of hose clmaps to carry with you everywhere.
Old Sep 6, 2002 | 04:42 PM
Cartier1's Avatar
Cartier1
Default Re: Help with ATI procharger!!! (Red5)
thanks!
but the boost gauge is it right connected????? :confused:
Old Sep 6, 2002 | 11:07 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
If you have a Vacume/boost gauge that is normal. You car will be in a state of vacume untill you are in the throttle. Then you will make boost. If your gauge only shows ambient (0 boost) there might be a problem with the charger.
Old Sep 7, 2002 | 02:08 AM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
You've probably got a leak somewhere. Also check your blow off valve.
Old Sep 7, 2002 | 02:11 AM
JTE's Avatar
JTE
Default Re: Help with ATI procharger!!! (JTE)
Since the ATI is a centrifugal blower, you will only see max boost near redline. You likely won't see much boost below 3000 rpms.
To Help with ATI procharger!!!
