Engine noise... help identify
Old May 7, 2016 | 03:51 PM
bwill03z's Avatar
bwill03z
Default Engine noise... help identify
Cold start up. The ticking sound is coming from the pass side as you will see in the video. The sound does not increase with throttle. It seems to go away mostly once the car is warmed up. What are your thoughts?
Old May 7, 2016 | 06:06 PM
midnight01's Avatar
midnight01
Sounds like either a lifter, or a loose rocker arm/adjustment needed, if it goes away once the car is warmed up its because the clearances are tighter from the heat expansion. Does it do it after the car is shut off for a few minutes and you start it from warm?
Old May 7, 2016 | 06:26 PM
bwill03z's Avatar
bwill03z
I don't know I will check and see when I get a chance. I never really noticed it until today.
Old May 7, 2016 | 07:07 PM
73Corvette's Avatar
73Corvette
I can't listen to the video my PC audio is crapped out... but, I know there is an issue with valve springs breakage on some Z06 motors.
I would take an old broom handle/long screw driver and stick on where you think the sound is coming from and put your ear on the other end you will be able to hear EXACTLY where it is coming from if you keep searching for it and should give you a better idea of maybe what the problem is
Old May 7, 2016 | 07:11 PM
bwill03z's Avatar
bwill03z
One of the first things I did when I bought my car was swap out the valve springs. But I will work on trying to pinpoint where the noise is coming from
Old May 7, 2016 | 07:28 PM
73Corvette's Avatar
73Corvette
That would make me wonder for sure if a rocker arm needed adjusted...
Old May 7, 2016 | 08:32 PM
bwill03z's Avatar
bwill03z
Just looked at it again, the sound actually does get louder with throttle... once the car warms up it goes away. Let it sit for awhile turned off then cranked again... sound was back until operating temp.
Old May 7, 2016 | 08:36 PM
midnight01's Avatar
midnight01
Pull the valve cover and check the clearances of each rocker arm. One could be loose. And as your checking you can see if anything looks out of the ordinary.
Old May 9, 2016 | 04:46 PM
bwill03z's Avatar
bwill03z
I will do that as soon as I can.
If it is a lifter do you guys think a full Seafoam treatment might ne a good idea?
Old May 9, 2016 | 04:49 PM
midnight01's Avatar
midnight01
It won't help if the lifter is collapsed and it might not be a lifter. You won't know what it is until you pull the valve cover and check the rockers/pushrods. Do the easy troubleshooting 1st.
Old Jun 30, 2016 | 11:21 PM
bwill03z's Avatar
bwill03z
Ok guys one more video. I believe this noise has slightly increased. Valve covered was pulled and nothing out of the ordinary. If this is a lifter then should I park the car until it's fixed or is it not that big of a risk to drive? Again, noise goes away once motor is warmed up. Here is the vid
Old Jul 1, 2016 | 10:27 AM
David Shiel's Avatar
David Shiel
Default I am on my second C5 and
Ok guys one more video. I believe this noise has slightly increased. Valve covered was pulled and nothing out of the ordinary. If this is a lifter then should I park the car until it's fixed or is it not that big of a risk to drive? Again, noise goes away once motor is warmed up. Here is another video from today
https://youtu.be/n6ru6Lpk22Y
both sound like that when cold. This one has headers and they either amplify or increase the ticking sound. Goes away when hot. Since they both did it, I chalk it up to an engine characteristic and drive it like I stole it. Puts out dyno RWHP 342 and BHP 394+ or-, so I have to get on it alot to keep up with the Mustangs in our muscle car club. Runs right up to redline, idles smoothly at 550 and runs like a scalded dog, so why worry? If it blows, we'll put it back together!
Dave
Old Jul 1, 2016 | 02:39 PM
bwill03z's Avatar
bwill03z
Dave
So both of yours made that same tapping/knocking sound? Mine used to very quiet, other than normal ls ticking, but this strange sound just recently started. No power loss or anything like that but I did have metal shavings in my oil which concened me. I don't know if it's related to this sound or not.
Old Jul 1, 2016 | 06:15 PM
midnight01's Avatar
midnight01
if the noise goes away when the car is warmed up it is a clearance issue. A bad lifter will tick like that all the time hot or cold. I had a bad lifter in my Z28 that would make that noise hot or cold. get a stethoscope or a tube that you can press up to a few places so you can try and single out exactly which cylinder is the issue. Then you can check the preload on the rockers and also spin the pushrods to see if they are bent.
Old Jul 1, 2016 | 06:30 PM
bwill03z's Avatar
bwill03z
If it were a pushrod then woudln't the sound also not go away once the motor was hot? Also what can cause a clearance issue?
Old Jul 1, 2016 | 06:42 PM
midnight01's Avatar
midnight01
Time causes clearance issues, spirited driving, e.t.c. back in the old days (lol) if you didn't have polylocks for your rocker arms they would have to be adjusted every 20-40K miles because the bolts loosen up over time due to vibration and high rpm driving. a bent pushrod when cold would also have different clearance. I'm not saying it is a bent pushrod just don't rule it out and not check them.
Old Aug 19, 2016 | 08:32 PM
bwill03z's Avatar
bwill03z
So I was looking into this noise again. I used a screwdriver and tried to pinpoint where the clacking sound is coming from and it is def not coming from under the valve covers, but more of where the arrow is in the pic ( see below) thoughts??
To Engine noise... help identify
Old Aug 19, 2016 | 08:58 PM
LoneStarFRC's Avatar
LoneStarFRC
My money's on a lifter. Sounds like a roller self-destructing.
Old Aug 19, 2016 | 10:13 PM
bwill03z's Avatar
bwill03z
If so, what's the solution for this? That is probably why I had excessive metal shavings on my magnetic drain plug on my last oil change. It was the first change with the mag plug so I can't compare to any previous oil changes.
Old Aug 20, 2016 | 02:51 AM
LoneStarFRC
Pull heads, replace lifters AND cups and possibly cam; lobe probably damaged. Remove and clean pan, clean both heads.This is if level of debris is minimal.
Ideally pull engine and clean contamination, replace all bearings.
