white smoke after new head install
Old May 8, 2016 | 10:05 AM
ChrgedZ06's Avatar
ChrgedZ06
Default white smoke after new head install
I have a 2002 supercharged Z06 and one of the factory springs broke, therefore I took both heads off and sent to head shop to have heads rebuilt and replaced springs with a dual spring kit. Now after installing new heads when I first crank it up white smoke comes from exhaust and then goes away, I also notice it when I stop sometimes and take off at redlights. Strong smell of fuel inside cab also. Any suggestions would be appreciated. Maybe need retuning? Gasket leak?
Old May 8, 2016 | 10:29 AM
helga203's Avatar
helga203
My thought is valve seal leaking. When you turn the car off oil leaks into the cylinder and when you first start the car it burns the oil away. JMHO
Old May 8, 2016 | 10:42 AM
SPEED750's Avatar
SPEED750
Have somebody else start the car so you can smell the smoke. If it was oil it would be blue.
Gas is usually white. Check your dipstick and make sure the oil looks good. Sometimes a leaky head gasket will make your oil look like a milkshake.
Old May 8, 2016 | 11:24 AM
ChrgedZ06's Avatar
ChrgedZ06
That was my first thought, really didn't want to pull the heads again! Thanks for the advice
Old May 8, 2016 | 12:40 PM
tommypenguin's Avatar
tommypenguin
White smoke is coolant I would make sure you know what color the smoke is definitively. If it is white could be that the heads were not torqued down correctly or in proper sequence. Could also be due to the deck and head surfaces not be flat enough for a good seal under pressure. If the smoke is only at startup and is blue like others said it's likely a valve seal. Good luck.
Old May 8, 2016 | 01:59 PM
grantv's Avatar
grantv
Agree with above, white is coolant as far as I've ever known. Bad gaskets, surface not flat or clean, crack, torque incorrect...
Old May 8, 2016 | 04:06 PM
LoneStarFRC's Avatar
LoneStarFRC
I agree with most of the above, especially the coolant. Cooling system pressure check should be performed immediately.
Wrong or incorrectly installed head gasket??
Old May 10, 2016 | 03:59 PM
Bleachcola's Avatar
Bleachcola
did you check all the head bolt holes in the block for any fluid? or clean them out dry
Old May 11, 2016 | 03:11 AM
GravelSurfer83's Avatar
GravelSurfer83
Did you put thread sealant on the rocker bolts? That usually only applies to ported heads but worth a shot.
Old May 11, 2016 | 12:05 PM
zeevette's Avatar
zeevette
In my SC'd car, I installed the heads using thick MLS gaskets, and a coating of copper spray.
To white smoke after new head install
