Headlight Adjustment??
Old May 10, 2016 | 07:38 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Headlight Adjustment??
I have a 99 C5 that had an issue with aftermarket headlights...
The driver side headlight was jury rigged in the bracket and it broke two of the three mounting tabs so I bought a new set and after fixing the adjusters tried to mount the headlight assembly. What a PITA it was but now the assembly is not level like the passenger side and I can't get the surround on. Am I missing an adjustment some where ?
Jim
Passenger Side
Driver Side
Passenger Side Spacing
Driver Side Spacing
Old May 11, 2016 | 03:45 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
[QUOTE=BRAVO1;1592187118]I have a 99 C5 that had an issue with aftermarket headlights...
Jim
Driver Side
Wow!! It looks to me that you have two passenger side headlights! On the driver's side the housing angle is all wrong and if you flip it, it would match the passenger side...hence my conclusion that you are missing the correct right side housing.
Old May 11, 2016 | 03:46 PM
BRAVO1's Avatar
BRAVO1
VETERAN
NEVERMIND.......MECHANIC ERROR....They can be mounted in the wrong orientation.
Live and learn.......
Jim
Old May 11, 2016 | 03:47 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Headlight
[QUOTE=Road Runner;1592193145]
Jim
Driver Side
CORRECT !!! What a dumb*** I am
Old Feb 15, 2018 | 09:32 AM
mpolhem's Avatar
mpolhem
Bravo,
Where did you get the mounting tabs?
Old Feb 15, 2018 | 09:40 AM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Mounting Tabs
Originally Posted by mpolhem
Bravo,
The tabs are part of the headlight assembly....PM if you need more info.
Jim
To Headlight Adjustment??
