Help! Excessive shaking at 65+
Old May 16, 2016 | 01:46 AM
CactusCat's Avatar
CactusCat
Shaking could be from several areas. You didn't state whether manual or automatic transmission. That could help as well. Could be tires, wheels, torque tube or bushings, pilot bearing, and so on. The tires should all be checked first as thats the easiest and most likely. After that, wheels checked for roundness. After that, you have to become Sherlock Holmes and start doing your detective work. GL and keep us posted.
Old May 16, 2016 | 12:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by gimp
So in addition to C6Z shocks, you'd also suggest the Z06 (C5? C6?) leaf springs, sway bars, and metal end links?
YES BUT,,,,,ONLY from a suspension performance improvement stand point.
If you have damaged steering /suspension components, all that stuff wont fix that.
If you have the car on the ground and engine running and have someone inside the car turn the steering wheel slightly LEFT & RIGHT,,, while you examine all of the steering components, you might see some damaged stuff..
Look at the steering rack, ball joints control arms, tie rods ect and see if there is any LOST MOTION or deformation when the steering rack TRIES to move the tires. See if the steering rack tries to move within its mounts. IT SHOULDNT!
That's a quick and dirty way if inspecting for damaged parts.
BC
Old May 16, 2016 | 01:07 PM
mikeam's Avatar
mikeam
Get all 4 tires "Road Forced Balanced" runs around $100 for all four.
Originally Posted by sramos
Hello all,
I recently purchased a 1997 corvette with the suspension mode option. When I bought I had a few things fixed. One of the front wheels was bent, so I replaced with an original one, and with 2 new front tires, as well as a full alignment.
At 65+ the car shakes excessively. Since it does have the F45 suspension option, could this have anything to do with the shaking? I don't believe the suspension mode is working, as I've never felt an difference, and the suspension looks to be original. The car has 127k miles.
Old May 16, 2016 | 01:21 PM
grantv's Avatar
grantv
Originally Posted by RockyL32
I didn't see this mentioned anywhere else but when the car hit something hard enough to bend the rim it's very possible there are some damaged suspension or steering linkage as well
Thank you. Started reading and it seems nobody else alluded to this. If there's a bent wheel, there's very likely damaged steering and/or suspension parts IMO.
