Gc 0W30
Old May 15, 2016 | 04:33 PM
bwill03z's Avatar
bwill03z
Default Gc 0W30
Where do you guys get yours? It's time for another oil change so I just went with Mobil1 5w30 because no local stores carry the gc 0w30. Next change I want to try this stuff out. Is there a good place to order is from online? Thanks
Old May 15, 2016 | 06:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What's with the need to use ZERO weight oil?
Unless you live in a very cold climate,, 5 or even 10-30 will work fine. IMHO, zero weight at start up is crazy unless you are living in subfreezing environments..
Where do you live? Maybe that why you cant find it. Is NOT a big seller..
BC
Old May 15, 2016 | 07:26 PM
bwill03z's Avatar
bwill03z
BC
That was my thought when I first found out about, but apparently it is very popular in the LS community. It has provided very good results in oil analysis tests and seems to work really well in our motors.
Old May 16, 2016 | 10:27 AM
04zjimc's Avatar
04zjimc
Great oil... I get it at autozone or advance auto.
Old May 16, 2016 | 10:55 AM
bwill03z's Avatar
bwill03z
I have an advance auto, autozone, napa, and oreillys and none of them carry it
Old May 17, 2016 | 04:14 AM
Cliff8928's Avatar
Cliff8928
It appears that they recently changed from the 0W-30 to 0W-40 for the German produced Castrol from what's on the shelf at AutoZone.
Old May 17, 2016 | 09:09 AM
killian96ss's Avatar
killian96ss
Mobil 1 makes a 0W-40 European oil which works well in American V8's. Very good low and high temp protection. Ive been using it in all my vehicles for 20 years now with good results.
Steve
Old May 17, 2016 | 09:19 AM
bwill03z's Avatar
bwill03z
Steve
I got the castrol syntec 0w40 on sale for very cheap at autozone. I put it in my 5.3 silverado and caused it to have a knocking sound so I drained it and put m1 5w30 back in... knocking gone.
Old May 17, 2016 | 12:38 PM
killian96ss
Sounds like your 5.3 has other problems like worn out bearings that the lower viscosity oil revealed. The 0W-40 actually has better high temperature stability and protection than a 5W-30, but in reality they're not all that different.
Steve
Old May 17, 2016 | 01:23 PM
bwill03z's Avatar
bwill03z
Steve
Yeah possibly. It was only on startup that I had the knocking, once warmed up the sound went away.
To Gc 0W30
