PleaseHelp with odd shaking issue
Old May 17, 2016 | 11:07 AM
theheartbeat's Avatar
theheartbeat
Default PleaseHelp with odd shaking issue
I've noticed some sort of shaking or studdering issue with my auto car. This problem happens at 50-60 mph only. It seems like the trans keeps trying to shift in some type of way. You can actually feel car the jolting forward and then being held back. If you shift into nutural thr issue stops instantly. Any help would be appreciated.
Old May 17, 2016 | 11:57 AM
grantv's Avatar
grantv
Torque converter issue? Not locking up properly?
Edit; I haven't had an auto for about 20 years... so I'm guessing. Can you force the car to stay in 3rd gear, or do our cars not allow this?
Old May 17, 2016 | 12:08 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
We need to determine if it's related to RPM or vehicle speed. My car behaves very similarly (6 speed) and we've determined that the O2 sensors are old and not sending a good signal to the PCM causing a shuddering sometime a little jerky feel at speed. It idles fine and accelerates well. Cruising speed running in the upper gears just feels like it runs uneven sometimes. I have new sensors to install and that should fix it. What year is yours and how many miles are on your car? the older sensors do not like blended fuels and cases a mixed signal to be sent to the computer.
Old May 17, 2016 | 01:19 PM
theheartbeat
04 30k
Old May 18, 2016 | 12:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The very best thing that you can do for us to properly assist you in solving this issue is to read and post the Diagnostic Trouble Codes (DTCs) that are being displayed.
IF,, you have a TON of old history DTC, CLEAR ALL of the DTCs. Take the car for a drive and when the issue happens READ THE DTCs prior to turning off the ignition.
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
To PleaseHelp with odd shaking issue
