Hissing Sound?
Old May 18, 2016 | 07:33 AM
huesmann's Avatar
huesmann
Default Hissing Sound?
This morning when I started up I heard a hissing sound, coming from what seemed like the gauge cluster--definitely from drivers side, not passenger. It sounded like radio static, but it was still there when I turned off the radio. Not super loud, kind of like a small vacuum leak. The sound level didn't change when goosing the throttle in neutral, but did decrease when accelerating in gear.
Ran the codes and other than the B0367 code which pops up occasionally and the TPMS codes (dead sensors) I got a U1160 H, which seems to be a comms fault with the LDCM. Since it was an H code, I don't think that has anything to do with the sound I heard.
Anyway, about 25 minutes into the drive the sound either went away or became so faint I couldn't hear it over the other car noises.
Ideas?
Old May 18, 2016 | 09:43 AM
pmr2000's Avatar
pmr2000
Maybe the air pump lines to the check valves? they are pretty close to the firewall by master cyl.
Old May 18, 2016 | 12:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ALL of your HVAC damper controls are vacuum operated. Operate all modes of the HVAC level controls and see if all of them are able to be properly commanded (DEFROST Air to FEET, Air to middle and the RESERC/FRESH AIR control
VACUUM CONTROLER MODULE:
More vacuum stuff:
To Hissing Sound?
