Is this normal...???
Old Sep 7, 2002 | 06:30 PM
97C5ENVY's Avatar
97C5ENVY
Default Is this normal...???
Here's two different shots of my clutch reservoir: one of the rubber insert w/tons of moisture built up on it and the other of the reservoir insides w/tons of blackish gunk built up on it. Is this normal?
[Modified by 97C5ENVY, 4:33 PM 9/7/2002]
Old Sep 7, 2002 | 06:35 PM
Garceeya's Avatar
Garceeya
Default Re: Is this normal...??? (97C5ENVY)
Yup!!!
Looks exactly like mine right now. You need to clean this out often especially with an aftermarket clutch. I replaced with Castrol Synthetic. You will notice a difference eventually. I clean mine out once every other month. I just use some paper towels to soak it up and then refill the resevoir.
Old Sep 7, 2002 | 09:27 PM
97C5ENVY's Avatar
97C5ENVY
Default Re: Is this normal...??? (Garceeya)
I thought moisture was bad for hydrolics. :confused:
I can say this, i've had this moisture and blackish gunk build up occur ever since i bought the vette 3 years ago. But like you i just clean it out with a paper towel and refill it.
To Is this normal...???
