Low voltage warning on dic
Old May 23, 2016 | 02:18 PM
johnson333's Avatar
johnson333
Active Streak: 90 Days
Default Low voltage warning on dic
Greetings,
I have a brand new battery I purchased from autozone a few weeks back. http://www.autozone.com/batteries-starting-and-charging/battery/duralast-gold-battery/53436_176353_0/?checkfit=true
I have not pulled any codes as of yet. I do not drive the car but maybe once a week because of the crappy weather we have been getting in Ohio. I just noticed this message today upon starting the car to take for a ride. I have never seen this before. I have a stock 98. I have put on a battery tender the last few weeks, but i did not have it on for the last 3 or 4 days. Am I being ignorant or is this normal for this car to drain battery this quickly over the course of a few days?
Old May 23, 2016 | 02:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are several issues that can cause the LOW VOLTAGE issue/message.
You need to fully charge the battery and then see what the battery current draw is when the car is in sleep/security mode.
Is the low voltage message coming up after you start the car or before you start it?
When you see the low voltage message, you really should read the battery voltage DIRECTLY on the battery terminals with a DC Volt Meter and see if its really LOW. Post what that reading is.
BC
Old May 24, 2016 | 01:08 PM
johnson333's Avatar
johnson333
Well, the voltage meter started at 12.6 dropped to 11.41. I have had on battery tender plus since yesterday, the light is still red as of this posting. Possible bad battery? Production date on battery is April 2016,
Words of wisdom?
Old May 24, 2016 | 02:14 PM
johnson333's Avatar
johnson333
Originally Posted by 8VETTE7
What is the voltage across the posts without the tender connected?
That is the reading without tender on it
Old May 24, 2016 | 02:46 PM
johnson333's Avatar
johnson333
thank you
Old May 24, 2016 | 03:09 PM
SG Lou's Avatar
SG Lou
Return the battery to who you bought it from................ 11.4 is DEAD....
Old May 24, 2016 | 03:47 PM
johnson333's Avatar
johnson333
Just got a replacement, will find out now.
Thank you all
Old May 24, 2016 | 07:49 PM
73Corvette's Avatar
73Corvette
Insure it is FULLY charged BEFORE you install it........... Batteries sitting on the shelf at a parts store are seldom fully charged.
AND a tender won't FULLY charge it...put it on a CHARGER
Old May 25, 2016 | 12:12 AM
LoneStarFRC's Avatar
LoneStarFRC
While you're at it, check the battery cable lead for looseness where it attaches to the starter solenoid. Don't just eyeball it and think "it LOOKS OK", you need to actually CHECK it for tightness. That is where the alternator cable goes to, and is also the post where the battery gets it's charging voltage from.
There are two large red cables attached there, one from the alternator, the other from the battery itself. Obviously the battery needs to be disconnected first while you check the nut for tightness.
To Low voltage warning on dic
