Rear Engine Seal
Old May 26, 2016 | 10:13 AM
NavyGunner1980's Avatar
NavyGunner1980
Default Rear Engine Seal
Hey Guys,
I have a 2003 Coupe and I have an oil slick growing in my driveway.
I have already replaced the oil pressure sending unit, any Ideas?
Is the worst case a rear engine seal? if so any ideas on how much that should cost?
Tony
Old May 26, 2016 | 10:32 AM
nsogiba's Avatar
nsogiba
No way to tell what needs to be replaced until you find the source of the leak. Get it in the air, clean all the oil off the bottom off the car THOROUGHLY, and drive it until it drips again. If it's a rear main seal, that will require removal of the torque tube, transmission, etc. Cheap part, expensive labor.
You didn't mention if your car had a 6 speed, but if it does, that would be a good time to service and inspect your clutch/TT components if they need work.
Old May 26, 2016 | 10:35 AM
NavyGunner1980
Sorry it's an automatic.
So far I got a quoote of 7.3 hours labor @ $105.00 hr from a Chevy Dealer, does this sound right to you?
Old May 26, 2016 | 11:32 AM
zachaeous's Avatar
zachaeous
That does not seem out of line to me from a dealership.
My oil pan was leaking at both rear corners and I chose to pull the engine for the repair.
Good luck with your repair.
Old May 26, 2016 | 12:57 PM
NavyGunner1980
Do you have to pull the engine to tighten the oil pan bolts?
Old May 26, 2016 | 05:23 PM
zachaeous's Avatar
zachaeous
You do not have to pull the engine to just tighten the oil pan bolts. I had other issues which I needed to address so that is why I removed the engine.
The oil pan gasket can be changed by lowering the cradle or dropping it completely down. The gasket on the LS1 is a very good gasket and seals well if you follow the FS manual instructions. The engine has to be supported from above either way you go.
Old May 26, 2016 | 09:55 PM
AZDon's Avatar
AZDon
Cruising
Hey Gunner, I just did the rear main seal on my 2000 auto. Cost $1200. As others suggested, get it in the air and clean it thoroughly. There's an inspection plug on the bottom of the bell housing. If you pull that you can view the seal through holes in the flex plate. I had a quote of 900 to do the pan gasket for comparison, if it's that. Good luck.
Old May 27, 2016 | 12:14 AM
c_white's Avatar
c_white
Oil dye kit is your friend
Old May 27, 2016 | 09:39 AM
NavyGunner1980
I'm not even sure where to look, is the inpection port on the top or the bottom of the bell housing?
Thanks again
Tony
Old May 27, 2016 | 10:16 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TONY
The ONLY way to get to the bottom of this issue with out spending a SMALL FORTUNE is to get under the car and WIPE DOWN EVERYTHING. Get the engine and underside of the car clean and then,,, take a short drive and then REINSPECT the bottom of the engine. FOLLOW THE OIL!
You will be able to figure out if the oil is coming from the FRONT, REAR, ABOVE ect....
The STEALERSHIP may suggest that you change the REAL MAIN SEAL and it may NOT fix the issue. Then, there going to do ANOTHER DOLLAR RAPE to charge you for something else that "IS THE SOURCE"
NO one here can 100% tell you whats leaking. YOU have to do some hands dirty research and get your OWN idea on if the source of the leak points towards the REAR MAIN!
It could very well be that but, you still could have OTHER places that are contributing to the GUSH!
NOTE & WARNING!
PLEASE DO NOT HOSE OFF THE TOP OF THE ENGINE! You will wet things that will NOT be happy when you are finished! You can use some brake parts cleaner to WASH oil / dirt/ ect from the back of the block as it evaporates fairly quickly.
You can however use some engine cleaner like GUNK on the BOTTOM (lower part of the block) and hose that off. Then wipe down the remaining oil.
SO,,,, IMHO, If you don't invest some TIME under your car, just throw your credit at the service manager and say, CALL ME WHEN IT WONT GIVE YOU ANY MORE CASH!
Old May 27, 2016 | 10:59 AM
NavyGunner1980
Originally Posted by Bill Curlee
TONY
NOTE & WARNING!
Thanks Bill,
I'm not afraid of getting dirty, I'll be doing that this weekend :-)
Thanks again for your help.
Old May 27, 2016 | 07:05 PM
AZDon's Avatar
AZDon
Cruising
Tony, pick up a few cans of cheapo brake cleaner and some rags. I threw an old tarp under the car to keep the mess off the shop floor. Put on some safety glasses and get under there and blast away. Brake clean makes pretty quick work of it. I just ran the car on the axle stands for a while and then climbed back under there to inspect. Once you're under there there you'll see an oval, rubber plug on the bottom of the bell housing. Pop it out and you can view the rear main seal with a flashlight.
Old May 27, 2016 | 08:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
POP that plug and wash out the rear of the BLOCK / REAR COVER also. Then you will know if it coming from that area..
To Rear Engine Seal
