head stud?
Old May 28, 2016 | 11:06 AM
slider_buck's Avatar
slider_buck
Default head stud?
monday im finally installing my heads and cam. ive searched but cant find a direct answer as to what to torque the head studs to. what is the correct torque for the studs? i found more people saying 75 on the big ones and 22 on the little ones. is that correct? i'll be using molly lube to torque them.
Old May 28, 2016 | 11:48 AM
73Corvette's Avatar
73Corvette
MAKE SURE that the block bolt holes are DRY!!! Other wise, you will damage the block. (that applies to installing any fastener in the block).
https://www.corvetteforum.com/forums...questions.html
http://www.lbfun.com/warehouse/tech_...orqueSpecs.pdf
Old May 28, 2016 | 12:17 PM
StingrayRebel's Avatar
StingrayRebel
the studs themselves do not get torqued, you will torque the nuts that go on the studs... if they are arp studs they have instructions on their website
Old May 28, 2016 | 09:24 PM
slider_buck
thanks alot
To head stud?
