ac pulley noise?
Old May 31, 2016 | 08:14 AM
woodvette03's Avatar
woodvette03
Default ac pulley noise?
having trouble with ac belts breaking. had the belt off all winter and just put a new one back on the other day since it is getting hot again. upon starting car, heard some kind of clicking noise then goes away after a few minutes. did not hear it when belt was off all winter. i have heard this noise before. i am guessing the ac idler pulley or tension pulley. anyone have any experience or thoughts on this?
thanks so much in advance for your replies.
Old Jun 1, 2016 | 01:10 AM
BigGun's Avatar
BigGun
Bad pulleys usually don't break belts or heat them up. I would take a close look at the compressor when you inspect the pulleys. Does the ac work if the belt stays on?
Old Jun 1, 2016 | 07:31 AM
woodvette03
the ac works perfectly fine. it makes the normal sounds it should such as clutch engaging, etc. thanks.
Old Jun 1, 2016 | 10:06 PM
Moto One's Avatar
Moto One
Just a FYI; mine was pumping cold air right up till the compressor seized. I to thought the noise at first was the pulley clutch was making the noise. No, just the compressor eating it self.
Mark.
Old Jun 2, 2016 | 07:09 AM
woodvette03
Mark.
it makes the noise when the ac is off and only lasts a minute or so. i hope it is not the compressor. thanks.
To ac pulley noise?
