radiator drain location
Old Sep 8, 2002 | 03:03 PM
canuckz's Avatar
canuckz
Default radiator drain location
I think the drain is the little spout on the bottom on the passenger side and the valve is the white plug above it.Am I correct?If so what tool do I use to open the valve ?I want to increase the antifreeze content for winter storage as we often get temperatures of -35 to -40 and the coolant only tests -20F now.My garage is heated but if the furnace should fail I want extra protection.
Old Sep 8, 2002 | 04:03 PM
Xssesive's Avatar
Xssesive
Default Re: radiator drain location (canuckz)
Yep that's it, it only turns 1/2 turn. I think I used pliers to get it loose and hand turned it after that.
