speedometer works... sometimes..
Old Jun 8, 2016 | 10:41 AM
Levert's Avatar
Levert
1st Gear
Default speedometer works... sometimes..
what you think the problem is??? works some days, some days it doesn't work at all. tire pressure monitoring system not working either
Old Jun 8, 2016 | 11:06 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The speed sensor is located on top of the differential (passengers side). I would start there and male sure that the sensor connector and wiring to the connector are in good shape.
Until you read and post the DTCs it difficult to guess whats wrong. What do you get for TPMS readings?? XXX or messages???
Old Jun 8, 2016 | 12:37 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Ended up replacing my sensor. Had a small crack in the plastic housing letting oil in and shorting it out.
To speedometer works... sometimes..
