Power window motor question
Old Jun 9, 2016 | 12:31 PM
ezombie's Avatar
ezombie
7th Gear
Default Power window motor question
Is is possible to change just the power window motor on a C5 or do you need to replace the entire regulator? If just the motor can be replaced, can it be done without removing the regulator?
Old Jun 9, 2016 | 04:07 PM
pmr2000's Avatar
pmr2000
Its possible but not practical and most likely the regulator will go bad before the motor. You would have to rewind the cabling into the new motor.
Even if regulator looked good and motor dead I would not give the regulator long, lot of crappy plastic guides and parts on the cabling.
I went with AC Delco off Amazon about $260, not too bad of a job to do if you take your time, measure, tape market when old positions were.
