C5 door boot removal/replacement
Old Jun 9, 2016 | 10:25 PM
dboldt's Avatar
dboldt
Default C5 door boot removal/replacement
I have a 2000 coupe and want to replace the ribbed rubber door boots.The door side easily came out but the car side wont come out. Is there aa trick to removing these? Thanks for your help.
Old Jun 10, 2016 | 07:14 AM
3sACROWD's Avatar
3sACROWD
It has been awhile since I've done it. I usually approach something like this with my hand forming an upside-down "U" shape and placing it over the boot so my thumb and forefinger are close to the chassis. (left hand for the driver's side and right hand for passenger side) Push your thumb towards the front of the car and start applying a downward and slightly outward force with your hand. (Kind of like tearing a bunch of papers motion.) The top of the boot should pop out or at least give you some room to put a screw driver in to pry it out. HTH
Old Jun 14, 2016 | 09:16 AM
dboldt's Avatar
dboldt
I was able to pry out one end of the boot from the passenger door. It's difficult to determine how the boot attaches to the car. Do both ends simply pull out? Thanks for your feedback.
Old Jun 15, 2016 | 01:46 PM
3sACROWD's Avatar
3sACROWD
Yes. That is what I remember. I'd double check on my car but it is currently in the shop.
To C5 door boot removal/replacement
