Security Light, No start
First time post so forgive me if Im not following typical protocol. I just purchased a new 02 z06 and I have been having the no start issue with the security light on. When I purchased the car the security light was on but the car would start every time with no issue, but since then there has been more and more no starts daily. I checked my codes and I had a b2721 that would remain around always so I cleared all the codes in the car but the car has not started since. I am waiting on a new key and while waiting I have tried the contact cleaner on the key pellets and ignition but it didnt work. If this key doesnt work tomorrow, how should i go about determining what is the actual cause? also was thinking about having the VATS system tuned out completely, is this an effective and smart way to handle this situation?
Any help will be greatly appreciated.
This issue was around when I got the car but when the key fixed it I went and put my headers on.
The car is lowered and no jack is present at the moment so bumping the starter may be tough to do. Worst comes to worst im going to kick start it to get it home where I have access to tools, jack, etc.
As it wears the pellet on the key can loose contact with the rollers that read the pellet or the rollers can become damaged from the sloppy fit of the key into the key cylinder.
I do not know of an easy fix for this problem and it is a PIA since the new cylinder does not come with the components to match the "keying" of the cylinder to your key. You have to go to a Stealership to have this done or find a local Lock Smith that has the pieces to do the "keying" of the cylinder to your key. Lock cylinder is a separate part from the ignition switch. The key cylinder in on the front of the ignition switch and turns the contact surfaces in the ignition switch.
If I were going to change the key cylinder, I would also get a new ignition switch and replace that while I had the dash apart. Many hundreds of threads about the problems caused by the crappy ignition switch that is in the C5. Changing both parts at one time avoids having to tear the dash apart a second time to replace the ignition switch because you cannot live with the symptoms of a bad ignition switch.
JMHO......So the car didnt start this morning but when the the key was in the crank position and I pumped the clutch I could hear the clutch pedal clicking. I had to push start the car today to get it home and tried once not going fast enough and it kicked over a bit when i dumped the clutch then died. The car would then turn over and crank to try and start but then die immediately (first time this had happened after a no start), no security lights present. We got some more speed and the car kick started fine with no security lights or anything and when I got home I tried the starting the car again multiple times and it worked fine.
Now that Im home I have access to tools, volt meter, etc. and I have a hunch it might be a connection somewhere. Before I pay the dealer tons of money, should I check the relays with a volt meter 8VETTE7, or are you pretty confident that I will need the key cylinder replaced?
Also sorry if Im asking too many questions. This is my third c5 vette and I have solved multiple issues with my previous cars by simply reading these forums but this is the first time I have had an issue I couldn't crack myself and Im just trying to absorb as much info as possible because I plan to have a c5 vette for most if not all my life.
Often when a starter starts acting up... IF it stops in just the right place it WILL not crank the motor... that is where the whacking the starter can sometimes trigger the contacts to do their thing and waallla it cranks... or if you JUMP start the car sometimes just a little more VOLTAGE will make it work... then your back to, it might or it might not depending on the connectons and voltage to the solenoid...JUST because it starts 10 times in a row doesn't mean the 11th time it's going to turn the motor over again...just depends on where it stops sometimes....YOUR bypassing the starter when you push start it so it fires up when you dump the clutch...Like 8vette7 THIS makes me think it is your starter...
When I pulled my starter, found that 'someone' before I bought the car, must have had the starter out, or replaced it.
The connections were just a 'bit loose' and resulted in rusted, burnt connections right there at the starter solenoid.
I cleaned up the connections, tightened everything very nicely.
Original starter still in there a year later.
Thanks for all the suggestions, I have been super busy lately so I have not had a chance to check all the connections and use the volt meter. I also was waiting to see if I could find any consistencies in the no start but there doesn't seem to be any although I have noticed some small things that may help provide some info on the situation.
Since my last post whenever the car doesn't start/turn over now the security light will be blinking, this is the only consistent thing I have noticed in regards to dash lights (security light will still turn on and off while driving with no consistency on when or where). There have been a couple occasions where the car didn't start and I pulled out and repositioned the key and it turned over and started up immediately (I was under the impression that once a no start happens the fuel would be shut off for two minutes so I thought this was interesting). Secondly, I have noticed that when the starter does turn over, it seems to take a bit longer cranking for the car to actually start running (maybe double the time as a typical crank over and start up from when I first got the car).
Since the one consistent no start at my buddys I have never had to try more than 3 times to start it so I was somewhat less concerned as it seems to work 80% of the time. I have now cleaned the key slot in the ignition with contact cleaner multiple times and also used an air compressor to try and blow any gunk out but I am still getting the same issue. Today I was in the area of a local corvette shop that was busy but took a quick look at it and bypassed the vats through an hp tuner, this turned the security light off but the car still would not start so he put the vats back in.
Is any of his information relevant in determining what this problem is? The corvette shop said they need to pull the dash apart and take a look at everything before they can give a firm diagnosis but they are busy until next week but at this point I think thats what Im leaning towards.
Also sorry if it seems like I am jumping back and forth between problems that is making it more difficult to diagnose. The car has no consistencies in terms of when, where, and why it wont start so its hard to report something accurate back to you guys.
Any help is greatly appreciated
were you getting the security light as a result from those rusted connections or was yours just simply not starting?
73Corvette
If the starter is bad like you suspect, how would you explain how any time the car cranks over it will start? I feel like it would still try and crank over if its a malfunctioning started rather then just simply not turn over at all. In all honesty you would probably know better then me, just seems weird how it randomly wont start
73Corvette
Now you need to go BACK to post #17 and start over...
DO YOU HAVE ANY CODES?
This may be reaching for a theory but it seems as though the majority of the time it has an issue starting up the car is either very hot in the sun or hot from driving it for a while. Could this also play into any connection related issue?
I am going to politely back out of this thread and leave it to those that know WAY more than I do about this system... watch and learn
GOOD LUCK I know these guys will get you going
