99 Intake Air Temp Sensor Circuit Question
Code is P0113 IAT Circuit HIGH.
Open circuit on TAN lead between Sensor and PCM.
I've actually pulled the PCM and checked condition of connectors.
Proved continuity on Purple, Ckt # 719, Lead # 57 on PCM Connector #2, the RED one.
Proved open circuit on Tan, Ckt # 472, Lead # 25 on PCM Connector #2, the RED one.
My question here would be, is there a 'common Breakage Point', like a spot somewhere in the harness that people have seen this wire break on a number of cars?
Thought I'd ask, before I start chasing through the entire harness between the PCM and sensor.
Installed New Dealer Chevy part (sensor) within an hour of problem surfacing.
No Change.
Had my OTC EVO plugged into the car, watching the sensor readings, and no change whatsoever.
Which led to in-depth diagnosis, using my factory service manuals.
UGH..
I don't have any good ideas for what it could be given what you've said. If all shows 'good', I'd be inclined to think I was checking the wrong wires or something of that nature. Perhaps take a good look at the actual connector that attaches to the sensor itself and see if the contacts in that are clean and make good connections.
Maybe put an ohm meter on the sensor itself and see if it changes value as the sensor is warmed and cooled. Bought a bum sensor possibly?
The MOST COMMON C5 rub thru spot for engine sensor functions is at the rear of the drivers side fuel rail where the drivers side engine harness bends around the black metal bracket at the rear of the drivers side fuel rail (The bracket is actually a safety device to keep the fuel rail from sheering off in an accident)
Look for a rub mark in the black harness tape or untape it and look for damaged wires:
