binding in reverse
Old Jun 19, 2016 | 11:20 PM
grassblaster's Avatar
grassblaster
Default binding in reverse
so when i back it up in my drive way i get a pretty strong bind what feels like up in the front end. the tire actually locks up
is this a brake or a wheel alignment? or something else? Last time i though i could smell something, like tire burning or clutch smell....kinda freaked me out
drives fine forward. no visible tire wear
2001 z06
Old Jun 20, 2016 | 10:29 AM
grassblaster
think i'll try 4oz of slip lock. should I do one 4oz container or 2?
Old Jun 20, 2016 | 03:11 PM
jmohn's Avatar
jmohn
I assume you refer to a friction modifier for the differential. If you've got a front tire locking up, when in reverse, modifying the action of the limited slip differential won't help. From your description, it would seem you've got an issue with a front brake.
Old Jun 26, 2016 | 10:29 PM
grassblaster
So never mind what i said about the rear end locking up.
its definitely the front break/wheel locking up in reverse when applying the break. What would cause this? no issues in forward.
Old Jun 27, 2016 | 10:36 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
JACK UP the front end and see if you can figure out what wheel is having the issue. Run the wheel in reverse by hand and see if you can get it to bind. Could be a wheel HUB issue and or a brake pad issue.
Only way to know for sure is to EXPLORE!
Bill
Old Jun 27, 2016 | 11:28 AM
LoneStarFRC's Avatar
LoneStarFRC
Bill
Yep. Gotta git yur hands dirty.
Old Jun 27, 2016 | 01:40 PM
73Corvette's Avatar
73Corvette
Bill
Great common sense approach... u r da man
To binding in reverse
