Replacing a directional/daytime running lights.
Old Sep 9, 2002 | 07:28 PM
WITVetteSC's Avatar
WITVetteSC
Default Replacing a directional/daytime running lights.
How do you replace the directional/driving lights on a1997 C5 vette. Any help would be great. Thanks in advance.
Old Sep 9, 2002 | 07:51 PM
Bracket_Racer's Avatar
Bracket_Racer
Default Re: Replacing a directional/daytime running lights. (WITVetteSC)
Just replaced mine last weekend. Go under the car behind the light, there is a black panel you need to unscrew 4-5 screws. Lower the black panel and reach up to get to the light fixture. Turn it, pop the fixture out of the housing, bring it down, replace bulb and reassemble. The only problem is getting under the front end. Hope this helps
