Horn doesn't work
Old Jun 25, 2016 | 01:16 PM
Randyman2002's Avatar
Randyman2002
Default Horn doesn't work
2002 coupe - Any suggestions on the best place to start with a horn that doesn't work? It doesn't work from the steering wheel or when activating the security alarm from the remote. There are no codes.
I have the GM Service Manuals but my experience at this site tells me this seems to be a common problem. Are grounds the right place to start. All that's been apart a couple years ago was the passenger door with a locking problem which I fixed.
Old Jun 26, 2016 | 09:56 PM
c6miller's Avatar
c6miller
This happened to me last week. If the horn won't work from the steering wheel or the fob, replace the relay under the hood. I think its #39. That worked for me. Good luck.
Old Jun 27, 2016 | 12:39 PM
v6turbo87's Avatar
v6turbo87
Originally Posted by Randyman2002
I don't believe 2,3,4 or 5 apply here.
I checked and replaced the fuse but it was fine. Since the battery is right next to the under the hood fuse box I used a test light on he battery negative post and looked for 12 volts at he horn fuse. There was no voltage. Both connectors for the fuse were clean but dead. Any other suggestions. The horn seems to be the only item that's not working. If there's no battery up to the fuse it seems that would be the problem.
If you look at the Schematic posted you will see that you will get NO voltage to the fuse if the relay is bad. I'd try a new relay and then go from there.
Old Jun 27, 2016 | 12:45 PM
imjdoggie's Avatar
imjdoggie
I'm having the same issue I think my problem is something in the steering wheel because the horn works on my fob every time I press it. Just started this weekend..........AND I needed my horn so I yelled and used my finger LOL.
Old Jun 27, 2016 | 01:44 PM
bsmutz's Avatar
bsmutz
I replaced my membrane with a new one (horn was on all the time, had to pull fuse) and it quit working within a few months (January to April). Any reason I can't wire the horn switches to a simple push button switch located on the top of the moveable part of the steering wheel (the panel with the logo in the middle)? 3 amps good enough? Sorry to hijack thread, hopefully kill two birds with one stone? Thanks!
Old Jun 28, 2016 | 01:14 PM
idohavemail's Avatar
idohavemail
This has been happening to me lately too. Horn will work from steering wheel sporadically, but works 100% of the time from key fob.
Old Jun 28, 2016 | 11:24 PM
jdvann's Avatar
jdvann
Some helpful links.
https://www.corvetteforum.com/forums...brane-fix.html
Old Nov 12, 2016 | 04:26 PM
Randyman2002
Default Update
11/12/2016 Update...... After leaving this sit for months and not doing anything after a 20 minute trip to pick up a new relay and 1 minute to install it my problem was solved.
To Horn doesn't work
