AC Gremlin
Old Jul 6, 2016 | 01:57 PM
C422's Avatar
C422
Default AC Gremlin
Hello again!
I've got a 1997 C5 with the manual climate control system. The blower motor was going bad (high-pitched squealing that started after the drain plugs under the hood got clogged and water backed up into the cabin, coming through the carpet beside the blower motor) and so I replaced it.
Just before replacing it, I started having a glitch where there would appear to be no power to the AC control head. The lights behind the recirc/fresh air buttons would go out and none of the ***** responded. Similarly, the blower motor would cut out. After a few minutes, everything would come back and work properly again.
After replacing the blower motor, I have no lights ever. So no AC at all.
Here in Georgia, that's pretty much unacceptable. I looked at my service manual and searched the forum, but I couldn't find this particular problem, especially not for the manual AC rather than the dual automatic one.
Any ideas? I wondered about the resistors behind the blower motor, but didn't want to just replace those ***** nilly.
Thanks,
-Kyle
Old Jul 6, 2016 | 02:32 PM
C422's Avatar
C422
And now I'm getting a "No Comm" code.
Old Jul 6, 2016 | 02:40 PM
C422's Avatar
C422
Originally Posted by 8vette7
which sensor is the no comm associated with?? Ie 10 - pcm or 28 - tcs or 40 - bcm....etc....
99-hvac
Old Jul 6, 2016 | 03:01 PM
C422's Avatar
C422
Originally Posted by 8VETTE7
Give me a little time to look at the wiring diagrams for the Manual HVAC.
There is a Serial Data Buss connection that is apparently having an issue but I need to see what it connects to on the Manual HVAC.
Thank you very much.
It worked intermittently, which made me think there was an open somewhere.
Another forum suggested a loose solder joint, but that sounds like something that I'm never going to find across the entire AC system.
Old Jul 6, 2016 | 04:57 PM
C422's Avatar
C422
Hope this helps..........
Thank you very much! I'll give the grounds a go and report back with what happens.
I'm hoping that since it was working intermittently, it's just something like a dirty ground.
Old Jul 6, 2016 | 06:33 PM
C422's Avatar
C422
Whelp, checked the grounds and star connectors to no avail. Fuses also looked good, though I was lazy and didn't measure across them (they looked brand new).
I'm not sure where my shop manuals are (moved on July 1st to my first house), but I guess it's time to tear into boxes to see if I can find them.
That or start sticking a meter on everything that looks like it's connected to the HVAC.
Old Jul 8, 2016 | 12:41 PM
C422's Avatar
C422
So, found my manuals.
Here's the schematic for the blower motor controls:
I don't have power to the control head.
That leads me to believe it's the blower motor relay, but I can't seem to find any good information on where that is.
Old Jul 8, 2016 | 01:26 PM
C422's Avatar
C422
Alright, I got behind the HVAC control head and tested from B (the red wire) to a ground (I used the passenger side courtesy light, because it was handy and colorblindness makes it a real pain for me to figured out if things are purple, dark blue, or black sometimes).
No voltage there.
Since I have no power to the control head, it looks to me like that relay has to be bad.
From what I've seen, it's supposedly above the passenger foot-well fuse box. I don't SEE it.
Old Jul 8, 2016 | 02:07 PM
C422's Avatar
C422
Before you go looking for the relay I would check out fuses 18, and 49 in the passenger foot well fuse box and also ground G202.
If those all are OK then you should look in the section of your shop manual for the HVAC for a component locator. I would hope the 97 manual has such a topic. The manual for my 04 does but has no info at all about the manual HVAC. Perhaps that didn't exist for that model year???
I did look up the owners manual for a 97 online and there is no mention of that relay in either of the two fuse boxes so at this point I have no further help I can offer on where the relay is located.
Maybe an owner of an early year car will post some additional info based on their experiences.......
I checked every fuse related to the HVAC I could find. 18, 19, 49, and even the compressor fuses, just hoping something else would magically be the problem,
The component section doesn't list the relay, but in the electronics section it EXPLAINS the relay. It just doesn't tell me where it is, as far as I can tell.
Old Jul 8, 2016 | 02:50 PM
C422's Avatar
C422
I just remembered this picture from my 04 shop manual. While it may not be completely correct for a 97, the location of the blower motor relay MAY be OK Worth a shot:
Attachment 47998656
There may be more than one relay in that location above the IP fuse box so use the wire colors in your diagram above to narrow down which relay is blower motor....
Out of curiosity, where was that in your book? I didn't see anything that looked like that in mine.
Old Jul 8, 2016 | 03:04 PM
73Corvette's Avatar
73Corvette
Under the section of the manual about steering. Specifically it is related to the Column Lock section. The 99 and later year C5's had a Column Lock Relay (CLR) that is somewhat prone to failure. The 97 and 98 C5's do NOT have a CLR. Rather the BCM directly operates the relatively high current lock motor.
I happened to remember that there were several relays shown in that area and as luck would have it the blower motor relay is mentioned.
But as many things did change over the years the C5 was produced, you need to check and see if that is where it is located on your 97.
One of those many times when you really miss Dadaroo...
Old Jul 8, 2016 | 03:10 PM
C422's Avatar
C422
So, those relays are definitely in the same place on mine. Now to try to figure out if they're the right things
Old Jul 8, 2016 | 03:46 PM
C422's Avatar
C422
Talked to a group of Corvette techs near me, and they claimed that the techs on duty haven't seen that relay fail before, and from the diagram, their best guess is that it's inline somewhere. So, fun times.
Old Jul 8, 2016 | 04:22 PM
C422's Avatar
C422
I found a '99 manual, and it has the same image for the under-the-dash relays. I can't believe that I can't find it in mine.
Old Jul 8, 2016 | 04:43 PM
C422's Avatar
C422
I would trouble shoot the voltages that operate the relay if it were me.
That isolates whether the problem is before or after the relay or whether your luck had the relay fail. Grounds are a major C5 problem so I would be especially interested in that. JMHO.....
I appreciate the help and input!
There're wires on the back of the HVAC control head that should have power assuming the relay is picking up. They don't.
The connectors on the back of the HVAC temperature actuator adjust **** and the directional adjust **** have power. Thereby, the **** back lighting gets power when the car turns on. And then... no power to the fan control ****.
None of the wires on the back of the fan control **** show any voltage.
None of the HVAC fuses are showing anything other than closed, as they should.
I'm... kind of at a loss if it's not wherever that AC relay is.
Old Jul 8, 2016 | 04:51 PM
73Corvette's Avatar
73Corvette
For SURE!!!!!
There have been many other threads of late where Sam's expertise would have been a big help!
Seem as though he had a schematic for EVERYTHING...usually had to wait for him to finish his beer and cigar and get home but, he always came up with it...cool dude
Old Jul 10, 2016 | 03:53 PM
C422's Avatar
C422
Default The plot thickens
I found the relay, and the relay wasn't sending out power, so I thought I'd found my problem. Decided to check the input to the relay (yellow in the picture) to make sure that was the problem. Lo and behold... no power.
Moved back to blue. No power.
Pulled the fuse and measured (red) and... no power.
So, where the heck does "hot in ON" come from to the fuse block?
I'm getting ready to pull the block to see if it's a loose connection on the back of the block or something, but checking upstream again would make me a lot happier about it.
Also, should I think about making a new post for this, since it's no longer as simple as the title implies?
To AC Gremlin
Old Jul 10, 2016 | 04:22 PM
C422's Avatar
C422
Another update: in Power Distribution (8-308) it's coming directly from the ignition switch. So this is gonna be fun.
Old Jul 15, 2016 | 02:16 PM
C422's Avatar
C422
Default Repaired.
So, I found the problem.
Took some extensive studying, but the problem was under the hood in the end!
Fuse 14, "Ignition 3/cooling" had some corrosion on it. That fuse is upstream of the brown wire that was the problem at the relay.
So if you don't have power at the AC relay under the passenger side of the car, check that fuse.
This weekend, I think I'll take the time to take pictures of every part, put them together with the manual, and try to do a write-up so that anyone else having electrical problems in the future with their AC should have some pretty good information on what to check.
Old Jul 15, 2016 | 02:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You may NOT have fully resolved your issue.
This is the first day that I saw this post. The initial first read of C422 post , I immediately thought " BAD IGNITION SWITCH"
Your car is at the age where that ignition switch is going to give you NUMEROUS ISSUES. The loss of HVAC Head control power is one of the symptoms.
So,, If you start to get some really weird electrical issues, you may wasn't to clean or replace that ignition switch if it has never been serviced..
Just sayen!
Gotta love that GA Heat!
Just got back for El Passo TX WHEW!
BC
