No bass after headunit install
Old Jul 12, 2016 | 06:32 PM
CastorTroy's Avatar
CastorTroy
Cruising
Default No bass after headunit install
Recently installed an Alpine head unit using the PAC ROEM-VET1 adapter harness in my Bose equipped 2000 Corvette. The mids and highs are fine, but the door subs are not getting any power at all. Local shop verified that I wired up the adapter properly. Fuses 5 and 28 are good. What else should I check?
Old Jul 12, 2016 | 07:32 PM
GCG's Avatar
GCG
The PAC ROEM-VET1 has built-in adjustment potentiometers to get the sound just right. I would suggest to begin there.
Regarding bass, here are a couple of suggestions:
1) Make sure the OEM C4 plug is connected to the PAC ROEM-VET1 harness, otherwise you'll have no real bass.
2) Also, make sure your BLUE WHITE from radio is connected to BLUE on the PAC ROEM-VET1. If you wired "blue white" to "blue white" instead, your door subs will not turn on and then no real bass neither.
Old Jul 13, 2016 | 10:35 AM
Cheesecake 07's Avatar
Cheesecake 07
Had the same problem/symptoms. This solved it.
Old Jul 13, 2016 | 02:02 PM
CastorTroy's Avatar
CastorTroy
Cruising
I'm sure that's what I did, thank you!
Is this something that's listed in the instructions that I missed?
Old Jul 14, 2016 | 11:06 AM
ascastil's Avatar
ascastil
Oh man. Ill have to check the blue wire also. I have some bass, but not nearly as good as before. Do you have a little bass, or no bass?
Old Jul 14, 2016 | 01:59 PM
GCG's Avatar
GCG
It doesn't hurt to double - check
Old Jul 15, 2016 | 02:10 PM
CastorTroy's Avatar
CastorTroy
Cruising
I just went through the instructions that came with mine again, and it mentioned nothing about the blue/blue white stuff. However, I see that their website now has another instruction sheet that specifically mentions it.
Everything is good now, thank you!
Old Jul 15, 2016 | 08:06 PM
GCG's Avatar
GCG
I'm glad everything is fine now
To No bass after headunit install
