still fighting window leaks
Old Jul 13, 2016 | 03:41 PM
beachbumznc's Avatar
beachbumznc
Cruising
Default still fighting window leaks
I know this horse has been beaten, recycled, and beaten numerous times. I had water leaks on passenger and driver side windows. Replaced targa top side and rear weatherstrip. I still have leaks, even under normal washing without pressure washer. I have attempted the tip in , but actually made it worse. I had thought about tipping it out, and slowly tipping it in til the leaks stopped. I know the c5's are notorious for leaks at high pressure, but this is just with the garden hose set on spray!!
any additional help or advice would be appreciated.
Old Jul 13, 2016 | 04:11 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
have you moved the door strike in, might make the door close harder (I would prefer that over a leak)????
Old Jul 13, 2016 | 05:03 PM
Eric Sr's Avatar
Eric Sr
How does the gasket look at the door jamb across the back of the targa frame and down to the other door jamb? If that makes sense...my weather strip is torn on both corners around the area of the pins that hold the top to the body...I'm hoping that is the cause for my leaks, at low pressure as well
Old Jul 14, 2016 | 08:36 AM
beachbumznc
Cruising
I did not think of moving the strike, but that makes sense. I will definitely give that a try.
As far as the gasket around the door jamb, it's new. I had minor leakage before I installed the new weatherstrip, but it go a little worse on the passenger side after I installed the new weatherstrip. I went back and toyed with the tip in a little more and improved it a little. I also put dielectric grease on them.
Last edited by beachbumznc; Jul 14, 2016 at 08:39 AM. Reason: left out a litle information
To still fighting window leaks
