Analyzing Hyperflash
Old Jul 14, 2016 | 12:09 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Analyzing Hyperflash
If a bulb or socket goes out/broken do all bulbs hyperflash ?? More to this story but fir now I'm curious about this issue.
Jim
Old Jul 14, 2016 | 12:44 PM
lionelhutz's Avatar
lionelhutz
If the load on the flasher is not high enough then the flasher goes to hyper flash mode. So, if a left turn signal bulb is out only the left turn signal would hyper flash. The right would not hyper flash because all the bulbs on the right are still there and loading the flasher.
Old Jul 14, 2016 | 12:54 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Well, I tried to install switchback DRL with a resistor and it still hyperflashed the LED. If you insert the LED in the opposite way the dash lights go crazy. So I ordered a harness to stop that but I cut off the resistor and now all bulbs hyperflash, front and rear when turn signal lever is pressed down. WTH did I do ??
Old Jul 15, 2016 | 11:37 AM
lionelhutz's Avatar
lionelhutz
The stock flasher can't cause a single corner bulb to hyperflash.
And yes, if you put LED's in backwards you can get exactly what you saw. When it's in the socket backwards no harness can fix it.
Old Jul 15, 2016 | 12:06 PM
73Corvette's Avatar
73Corvette
I'm guessing from your avatar and username you are military... so THANK you from one infidel to another for your service ..
Wait for the harness...
It just seems so simple... get an LED bulb plug it in and walaaaaa... nope, not in our C5 ... IT has to be complicated and confusing or it doesn't qualify.
Old Jul 15, 2016 | 12:56 PM
73Corvette's Avatar
73Corvette
Originally Posted by 8VETTE7
Guess I just must have been lucky because I ordered a complete LED conversion kit and hyperflash harness from one of our Forum vendors, installed it all and not a problem since. Every outside light on the car is now LED and no problems at all.
Of course now that I have said that Murphy's Law dictates that when I next drive the car I will have all sorts of issues....
Maybe I missed it but I thought the OP said he had ordered the harness... I assumed he hadn't gotten or installed it yet... hoping this will fix his issues... or that I miss understood and then you will have to bail him out
Old Jul 15, 2016 | 01:22 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Well as things progressed I thought I'll start the car and pull the codes from the DIC. Everything is OK now. Very strange indeed. Thanks to all who responded, that's the greatness of this forum. helping one another.
Old Jul 15, 2016 | 01:24 PM
73Corvette's Avatar
73Corvette
Guess I didn't get what I intended across. Not surprising because at my age no one understands what I say anyway. I ordered a tried and tested solution on a C5 and NOT a "one size fits nothing" solution that has not been proven on a C5 and included no specific info for all the different applications that it doesn't fit without modification.
well, that certainly cleared things up, you crack me up... did you order your harness from RadioFlyer?
Old Jul 15, 2016 | 01:30 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Yes it's on the way. Also, thank you for your service. i thought I blew up something expensive I'm relieved. Now I'll wait for the harness and do this all over.
Old Jul 15, 2016 | 01:38 PM
73Corvette's Avatar
73Corvette
I barely missed the draft for NAM... then was too busy chasing girls and getting stoned... later I was too busy raising a family and making a living to join... now I'm too dang old to join... wish I had many times...THANK YOU for serving!
To Analyzing Hyperflash
