Oil pan removal
Old Jul 14, 2016 | 08:51 PM
McMuscle91's Avatar
McMuscle91
Default Oil pan removal
03 z06 replacing oil pan gasket, when jacking up the engine does the torque tube have and other driveline parts have to be unhooked or can they move enough to slide the oil pan out?
Old Jul 14, 2016 | 09:02 PM
zachaeous's Avatar
zachaeous
I would dropped the front cross member/cradle to remove the oil pan. The engine has to be supported from the top to do this.
I have dropped the front cradle a couple of times and that is what I did. The torque tube was not disturbed.
Good luck with your repair
Old Jul 14, 2016 | 09:10 PM
McMuscle91's Avatar
McMuscle91
Great, thanks for your reply! Gonna do a c6 pan for a special build il be starting
To Oil pan removal
