Got a small oil leak coming out of one of the drains on the bellhousing. What's up in there that could leak? Rear main seal?
Coincidentally, I installed a dual catch can setup and deleted the pcv valve. I've since reinstalled the pcv after I found about 3 tablespoons of oil after driving just over 100 miles.
Well,,,,,,,,,,,,,,, If its a rear main seal, you need to consider replacing the CLUTCH and all the clutch other parts while you have the drive train out. Disassemble the Torque Tube AND replace the rubber couplers with new stock OEM GM couplers!
Also could be leaking from the cam position sensor or the the barbell, most likely is rear main however. Do preventative maintenance like bill suggested or you will be paying to do this twice.
