Faint fuel smell
Old Jul 19, 2016 | 09:22 PM
STRMLNE's Avatar
STRMLNE
Default Faint fuel smell
This can't be good. I'm getting a faint fuel smell in the garage and inside the car. Nothing leaking on the floor though.
Old Jul 19, 2016 | 09:43 PM
STRMLNE's Avatar
STRMLNE
Originally Posted by 8VETTE7
When was the last time the fuel filter was changed?
It's definitely been a couple of years. 4 or 5.
Old Jul 20, 2016 | 09:07 AM
AllredC5's Avatar
AllredC5
What does a old fuel filter have to do with fumes. I understand it may not perform as it should due to being dirty, but fumes. With age do they possibly have a chance of leaking? Maybe I should look into changing the one on my 2002 with 20,000 miles.
Old Jul 20, 2016 | 11:50 AM
Carl Timonen's Avatar
Carl Timonen
I'd do a visual of the fuel system for any weeping. Also check the evap canister for any lines that aren't connected, or maybe the condition of the canister.
Old Feb 17, 2026 | 05:07 AM
GeorgeKimbel's Avatar
GeorgeKimbel
2nd Gear
It sounds like your Corvette might be having a fuel delivery issue, and starting with the fuel filter is a smart first step since its never been changed. Sometimes a weakening fuel pump or partially clogged fuel injectors can cause sputtering when you go to full throttle, even if the car runs fine at normal speeds. Spark plugs or ignition wires can also play a role, though usually that would affect more than just full throttle. One thing that could help narrow it down have you noticed any changes in exhaust smoke or smell when it sputters, like it seems rich or lean?
Old Feb 17, 2026 | 06:08 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Originally Posted by GeorgeKimbel
It sounds like your Corvette might be having a fuel delivery issue, and starting with the fuel filter is a smart first step since it's hisnever been changed. Sometimes a weakening fuel pump or partially clogged fuel injectors can cause sputtering when you go to full throttle, even if the car runs fine at normal speeds. Spark plugs or ignition wires can also play a role, though usually that would affect more than just full throttle. One thing that could help narrow it down have you noticed any changes in exhaust smoke or smell when it sputters, like it seems rich or lean?
This is a 10 year old thread...OP probably has it figured out by now.
To Faint fuel smell
