Ls7 clutch zero balance
Old Jul 19, 2016 | 09:35 PM
kawaking12's Avatar
kawaking12
Default Ls7 clutch zero balance
Hi guys I read everything I could in the search . Its still not completely clear to me if the ls7 clutch comes both flywheel zero balanced and PP zero balance . I tried finding orientation marks on the new ls7 clutch I received today but could find something defenitive between all the paint marks .
Old Jul 20, 2016 | 11:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WELL<<<<<<<<<<<<<<<<<<<<<<<<<<<< A new GM unit that comes as a complete assembly should be zero balanced.
The problem comes from the actual OEM Factory installed assembly on you C5 may have off set balance pins installed in the outer rim of the flywheel.
It the HOT BALANCE procedure added pins to your flywheel, you will need to TRANSFER those pins to the exact same quadrant that they were on your OEM flywheel and to reinstall that flywheel on to the crank wher it came off to maintain that factory hot balance (MATCH MARK IT)
If you don't have any off set balance pins, you should be good to go.
BC
Old Jul 20, 2016 | 11:39 AM
SaberD's Avatar
SaberD
it doesn't matter if it's zero balanced or not because it needs to be match balanced to the original unit by a machine shop anyways. Even if it doesn't have pins, I would still do it just for reassurance.
Old Jul 20, 2016 | 11:53 AM
kawaking12's Avatar
kawaking12
ok I have a big issue then . On the island I live there is not a possibility to do a hot balance . the really small dealer we have here never heard of the hot balance and the car was not bought at the dealer so I don't have there backup .
The car started life as a automatic . the flywheel I found in it has the pin but the car would have vibration at 2000rpm . so I do not want to just transfer the pin . I think this is just going to be trail and error .
Old Jul 20, 2016 | 12:12 PM
73Corvette's Avatar
73Corvette
Old Jul 20, 2016 | 12:44 PM
SaberD's Avatar
SaberD
if you do not have the original flywheel you will need to do some trial and error. The easiest way to add weights would be to add a washer or two under a pressure plate bolt.
You put a washer under one bolt and note the RPM that the vibration occurs. The better the balance the higher the RPM will get before it starts vibrating. You can also use some vibration analysis apps for your smart phone as the accelerometers typically have a refresh rate of 100HZ which could detect vibrations up to 6000 rpm. Make sure you note the X and Y components of the amplitude because only one of these will not give you the full vibration amplitude. There's always a vector to the vibration, and that will never line up with only x or only y. Pretty simple to calculate if you know Pythagorean theorem. It's just a right triangle where you have the two sides and you calculate the hypotenuse.
You note the amplitude of the vibration and the RPM where it starts. You can plot a graph in excel and interpolate where the washers need to go without putting a washer under every single bolt. You may need to use heavier or lighter washers in addition to adding washers to adjacent pressure plate bolts. It will be a long and tedious process, but you will get there eventually.
Old Jul 20, 2016 | 02:23 PM
kawaking12's Avatar
kawaking12
I will let you guys know how it all turns out . I will be installing the clutch today but I will have to wait until I get my couplers in . to do final assembly and test for vibration .
Old Jul 20, 2016 | 02:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I helped a froum member in Canada a few years back who replaced the clutch and didn't pay any attention to balance.
We did the washers under the pressure plate bolts and he got it down to NO NOTICEABLE VIBRATIONS!
So, using that method can resolve the issue. I agree that being in your situation, DO NOT use the old weight pins!
There are also vendors who do vibration analysis for a living and can help you fix your vibration issues.. Google for them in your area.
BC
Old Jul 20, 2016 | 02:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here's a GOOGLE example of a search for CT =
http://www.thomasnet.com/connecticut...4863505-1.html
BC
Old Jul 20, 2016 | 03:10 PM
kawaking12's Avatar
kawaking12
OK awesome . As soon as I have it together and running I will let you all know . If you could help me I would really appreciate it .
Old Jul 20, 2016 | 03:30 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!!! I installed a SPEC Twin Disk Clutch and I was worried to death that I was going to have a vibration issue. SO,,,,,,,,,,,,,,,, I put the back of the engine on a stand and cranked it up with just the new flywheel to see if I had any weird vibrations from the just the new SPEC Flywheel that I had matched off set balanced to my old C5 ZO6 flywheel with off set balance pins.
SUCCESS!!!!!!! NO VIBRATIONS!
Heres a crappy video that was taken at 10:00 PM (Yea, the neighbors LOVED ME!)
OPEN HEADERS and YES,,, it was VERY LOUD.. Sounded like HEAVEN to me!!!
Just CLICK on the picture to play the VID
Old Jul 20, 2016 | 03:37 PM
kawaking12's Avatar
kawaking12
I don't see a link for the video
Old Jul 20, 2016 | 03:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try it now...
http://vidmg.photobucket.com/albums/...DSCF0074-1.mp4
Old Jul 20, 2016 | 04:04 PM
kawaking12's Avatar
kawaking12
ahahahahah that's awesome
Old Jul 20, 2016 | 04:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! It was FUN!
I ran it a LOT more the next day!!
Old Jul 20, 2016 | 08:52 PM
kawaking12's Avatar
kawaking12
I marked where the old pins are in case I need to transfer them to the new flywheel atleast I know where they go
Old Jul 21, 2016 | 01:19 PM
thbwlZ's Avatar
thbwlZ
If your car started as an automatic, then that flywheel is from another engine.
Any weights in that flywheel HAVE NOTHING TO DO WITH YOUR ENGINE. They were installed while final balancing the engine from which it came. Your engine was not final fine tune balanced.
The best thing you can do is have your new clutch assembly balanced as close to zero balanced as possible then install. If you feel vibrations, which you MAY, then you can do the iterative washer installation exercise that SaberD explained.
Any weights you find in that old flywheel are MEANINGLESS with regard to YOUR engine.
Good luck
To Ls7 clutch zero balance
Old Jul 21, 2016 | 01:29 PM
kawaking12's Avatar
kawaking12
thx guys . thank you very much for the help. I really really appreciate it .
I will let you guys know this weekend how it all turns out .
Old Aug 11, 2016 | 04:03 PM
kawaking12's Avatar
kawaking12
Hi guys . a small update . I have about 50miles now on the clutch and it feels awesome . no vibration . very smooth engagement . really like the clutch so far .
Installation was not so bad . just alot of work
I could not have done it in one time if it were not for all of your help .
thank you
Old Aug 11, 2016 | 04:19 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Drive it like you stole it!
Thanks for the UP-DATE! It means a LOT!
BC
