Rear outer tie rod, any special tool needed?
Old 07-24-2016, 08:42 PM
jdvann
jdvann's Avatar
Default Rear outer tie rod, any special tool needed?
.On my Y2K A4 vert, for Rear outer tie rod replacement, is there any special tool needed? Found side to side movement in my RR tire upon inspection and the movement is within the outer tie rod. Movement appears to be down in the rubber part on the other side of my finger down below...
Thanks for any help in advance.
Old 07-24-2016, 09:26 PM
Rob 02
Support Corvetteforum!
Rob 02's Avatar
I use a ball joint separator like the one pictured with good results.
Old 07-24-2016, 09:52 PM
jdvann
jdvann's Avatar
Originally Posted by Rob 02
Attachment 48003120
I found this cool video.
Old 07-24-2016, 11:27 PM
Rob 02
Rob 02's Avatar
That's good information. I replaced the inners as well, just to be done with it.
jdvann (07-24-2016)
Old 07-25-2016, 08:35 PM
gimp
gimp's Avatar
Attachment 48003120
I have this precise one. It is great.
A pickle fork will take your suspension apart wherever ball joints are concerned, but it is a destructive tool. A ball joint separator will allow you to re-use the rubber parts it comes into contact with. Very important if, say, you want to replace something that is attached to a ball joint.
Also, the bottom part of it (the fork part) can easily be used as a pickle fork, except it's a lot less sharp.
To Rear outer tie rod, any special tool needed?
Quick Reply: Rear outer tie rod, any special tool needed?
