help
Old Jul 27, 2016 | 07:26 AM
dminkalis1's Avatar
dminkalis1
4th Gear
Default help
2002 vette. did burn out spun around. abs and traction lights came on. started next day and lights off. 1 week later lights came back on. what happened.
Old Jul 27, 2016 | 07:50 AM
runner140*'s Avatar
runner140*
We always say first..."pull your codes". That how you know whats going on with your Vette. Report back to us with the complete numbers and letters and H or C.
Old Jul 27, 2016 | 10:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CODES BROTHER,,,,,,,,,,, You need to read the DTCs by using the cars internal DTC reader and post them.
Read the DTCS when the error happens. Do not turn the ignition off and the read them.
IF you have tons of DTCs, clear them and the post what returns.
Bill
Old Jul 27, 2016 | 10:38 AM
73Corvette's Avatar
73Corvette
Old Jul 28, 2016 | 10:21 AM
dminkalis1's Avatar
dminkalis1
4th Gear
Default help
have codes c1214 and c1226. cleared and have active c1214
Old Jul 28, 2016 | 11:03 AM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
The c1226 is left front excessive wheel spin. That should go off and stay off. C1214 Sol Valve Relay Contact or Coil CKT Open I will let others chime in, but if it were me. I would disconnect the battery for say 10 minutes and see if that takes it off. However, some of our great experts may no exactly. I am a novice. But that is where I would start.
Old Jul 28, 2016 | 11:06 AM
dminkalis1's Avatar
dminkalis1
4th Gear
Default help
Bill
have codes c1214 and c1226. cleared and code c1214 comes back
Old Jul 28, 2016 | 11:23 AM
dminkalis1's Avatar
dminkalis1
4th Gear
Default help
Bill
have codes c1214 and c1226. cleared and c1214 cames back
Old Jul 28, 2016 | 01:05 PM
popshumphrey
St. Jude Donor '16
I will shut up now. I can't even get the correct excessive wheel spin right
Old Jul 28, 2016 | 01:28 PM
73Corvette's Avatar
73Corvette
No... you keep at it... good way to learn... 8vette7 and Mr Curlee have had to set me straight on more than one occasion... I know I'll keep making mistakes but, maybe after 15 or 20 years on the forum I won't make as many...
Old Jul 28, 2016 | 03:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
1214 is your issue. Until you get that repaired (ABS FIXER) the EBTCM is in DEFAULT MODE and you have brakes just like a car with standard power brakes.
Take the electronic part of the module out and ship it to one of the ABS MODULE FIXERS..
EBTCM & BPMV module:
BC
To help
