This has been going on for years. Yes i do have HID lights but it was doing it before i installed them. It's only the driver side.
Things i did. Checked the yellow bumper to make sure they're all there and in good shape 3 of them. Next sprayed WD-40 on all moving parts.
I searched and only solution i found was that the bumpers where in bad shape or missing.
No codes. If i turn the *** it will work again for awhile.
I have the same issue with my PAX side headlight. I am assuming mine is a problem with the motor internals because all I have to do is move the ****, which is attached to the armature and it works for several cycles. I will get deeper into it during the winter hibernation. Mike
Mine does the same. If you don't hear grind it's the same problem i'm having.
