Rev limiter?
Old Aug 2, 2016 | 10:01 PM
kennedy759's Avatar
kennedy759
Default Rev limiter?
does my 1997 limit the rpm`s? reason I ask, is I was pulling codes and got one that said I exceeded 7400 rpms, its an automatic.
Old Aug 2, 2016 | 11:42 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
My 99 manual does at 6200 (was raised with a tune from 6000) if you hit 7400 I think your engine would be in pieces, or at least I would think so !!!!!
Old Aug 2, 2016 | 11:57 PM
v8srfun's Avatar
v8srfun
I can't see a stock engine turning that high for any amount of time it would certainly end in catastrophic failure
Old Aug 3, 2016 | 07:25 PM
gimp's Avatar
gimp
Have you been manually downshifting in your automatic at highway speeds? If not, you should be fine. (Even second gear at highway speeds in the A4 shouldn't go to 7400, should it? Second is 2.33 the ratio of fourth, and if you're at 2500 rpm at highway speeds, shifting to second would only be 5800 rpm.)
Old Aug 3, 2016 | 07:34 PM
StingrayRebel's Avatar
StingrayRebel
do you know if the tune has been altered?... 7400 is crazy high for an internally stock engine... if it is really revving that high I wouldn't expect the rod bolts to last very long if you continue to do that, especially on a 97
Old Aug 3, 2016 | 08:16 PM
kennedy759's Avatar
kennedy759
no manual down shifting, just a little street racing and 4 laps around the new bowling green track. no idea if its had the tune changed.
Old Aug 4, 2016 | 06:16 PM
gimp's Avatar
gimp
Hum. I might grab an ELM327 and the torque app or a similar app for your phone, whatever out there can log your RPMs for you. Drive around with that, review the data, see if your RPMs are ever reported to go that high. I would guess this is a spurious event, not real; 7400 is almost a thousand higher than your redline, and the automatic transmission should never let that happen.
To Rev limiter?
