I get the the SERVICE ACTIVE HANDLING message. I cleared the message and it went away, soon as I pull in the drive way it came back on. I left the engine running and pulled the code.
28 TCS C 1295 H
60 IPC U 1255 H
99 HVAC B 0361 HC
99 HVAC B 0441 H
A1-RDCM-B 2265 H
I reset the codes now. Any help would be appreciate. I looked in the forum for similar problems. its was real confusing.
I have LED brake lights and hyper flash installed . It's been about a moth since install LED headlights and LED turn signals. I still do not understand or missing the point . Go back to stock lights? That's what read in the thread you posted?
