Sway/Stabilizer bar advice needed.
rear sway bars to replace my stock ones. I'm not a racer, just
wanted to improve on stock bars. Stock bars sizes are front:
23mm, rear: 17mm. New bar sizes are front: 33mm, rear: 26mm.
Is this too much of a diameter difference or did I make an
error? Also, I replaced the original end links (which were
wore out) to Moog K750136. Will these links work with the new
bars or should I seek adjustable links? Last question, will
these new bars hit the control arms? Any advice/suggestions
from the senior members would be greatly appreciated!! Thank you.
The solid end links alone are a nice upgrade though. I don't know about adjustable links; are you thinking of adjustable bars?
The bars won't hit the control arms (if everything is installed correctly).
People said it is a one-hour job, so I must be "wrench-tarded" because it took me a lot longer.
C5 C6 sway bars specs
Base C5 (All Years): 23.0 mm front - 19.1 mm rear
Z51 C5 (97-99): 25.4 mm front - 21.7 mm rear
Z51 C5 (01-04): 28.6 mm front - 23.6 mm rear
Z06 C5 (All Years): 30.0 mm front - 23.6 mm rear
Base C6 (All Years): 25.5 mm front - 17.5 mm rear
Z51 C6 (All Years): 31.0 mm front - 25.4 mm rear
Z06 C6 (All Years): 31.0 mm front - 28.0 mm rear
GS C6 (All Years): 31.0 mm front - 28.0 mm rear
ZR1 C6 (All Years): 33.0 mm front - 31.0 mm rear
Eibach (C5): 29.0 mm front - 25.0 mm rear
Pfadt (C5): 34.9 mm front - 28.6 mm rear
Hotchkis 2284 (C5): 32.0 mm front - 29.0 mm rear
Hotchkis 2285 (C5): 32.0 mm front - 25.0 mm rear
The OP's bars are the same as a C6ZRI front and a shade larger than a C6 Z51 rear.
To the OP: what size wheels and tires are you running and with what shocks?
The sizes you mentioned are a popular upgrade and have gotten excellent reviews (z51 sways). You can get them new from Cultrag Performance, a forum member here, or used from eBay.
It should be the same bar just thicker. I wouldn't try to install it links first. I would fasten it to the engine cradle first.
Thanks for the input. I've decided to return the bars. For some reason they just do not fit on my car. I actually damaged the threads in my attempt. Luckily I had the correct metric tap handy and re-tapped the holes. All is good. Going to get bars from dealer and make darn sure the size is the same. Thanks again.
