I have a friend calling me about her 2000 coupe. She, and the dealer, says she has a check engine light but no codes. Is that possible?
I told her to disconnect the battery, wait a while and then try it again.
I did some searching here but I can't find anything.
She recently had the EBCM repaired and replaced.
Thanks in advance
That sounds very strage especially coming from a dealer---However the GM diagnostics is not as involved as someone using a TECH II or a tuner using HP or EFILIVE----
Do you know if all her readiness tests read READY ??
Finally the ECM is connected to the BCM for several of the car's functions-----I would guess that the NEW BCM is NOT communicating with the ECM--especially if you clear the code and it comes back----
PS ALSO the ECM's ODB2 port has a fuse----GM hides it on the Cigarette lighter circuit----Mkae sure this fuse is good----
