ac issue
Old Aug 18, 2016 | 04:11 PM
silver408z's Avatar
silver408z
Default ac issue
Symptoms: The ac compressor will not stay on at idle. It cycles on and off over and over. If you raise the rpm's it will stay on. Doesn't matter if you are driving or just give it gas while sitting at a stop. It blows very cold and strong when the compressor is on. No DIC codes for ac
Actions performed: The system was checked and showed to have good pressure, the system was evac'd and refilled to proper levels, oil was added(it was extremely dry), the expansion valve was replaced, the pressure sensor was replaced.
Idea's of the problem? anyone had this before?
Old Aug 18, 2016 | 05:05 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I had trouble with mine working when it wanted to and I found it was the relay ???? #34
Old Aug 18, 2016 | 11:37 PM
silver408z's Avatar
silver408z
Thanks for the response, I will check it out.
Old Aug 20, 2016 | 01:15 AM
poo23's Avatar
poo23
I had this problem as well. I was told I needed a A/C control head.
To ac issue
