Radio replacement
Old Aug 19, 2016 | 10:28 AM
thunder1951's Avatar
thunder1951
Default Radio replacement
I need to know what is entailed to completely get rid of the bose garbage sound system in my 98, I am now finding out that the door speaker amps and rear are having issues, I was going to have a kenwood double din installed but now I do not want to use any of the bose crap that is oem...i'm sure this project will brake the bank any advice and direction would be much appreciated.
Old Aug 19, 2016 | 06:36 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Look up forum sponsor Dennis, at "Double D Mods"......
Old Aug 20, 2016 | 01:43 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Deffinetly replace is all, new speakers and a 4 channel amp work wonders
Old Aug 20, 2016 | 04:59 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
https://www.corvetteforum.com/forums...ple-weeks.html
Old Aug 20, 2016 | 07:56 PM
Paul 75 L82's Avatar
Paul 75 L82
I took it all out.new Kenwood HU with Pioneer speakers and the Kenwood's little powered sub woofer. I love it, it's a project. Had to remove most all of the interior panels but it's worth it to have Bluetooth and iPod. Heck I have about 45 gb of music in the Corvette.
Old Aug 20, 2016 | 09:57 PM
Old Aug 23, 2016 | 07:39 AM
LoneStarLizzard's Avatar
LoneStarLizzard
I did the things you are contemplating about 4 years ago, including: Kenwood navigation head unit, 5 channel 900 watt amp, new coax cabin speakers, dual 8" subwoofers (mounted in the cargo area directly behind the seats) new door woofers and new tweeters (mounted in the A pillars) and a rear view camera. I bought everything from Double D Mods (Dennis' prices are about the best out there, plus he will take the time to consult with you to help design/select/install the system (and/or alternative systems) that best meets your wants. I don't know any other vendor who goes to the length Dennis does to help you get exactly what you want).
I did all of the install myself, with no help. I am a retired CPA with NO prior experience or training in these areas. But by following the many excellent show-n-tells found in the Forum, I successfully did all of the installation without a hitch.
Here are threads to some excellent write-ups that you may want to read:
1. How to remove the middle console: http://www.vetteessentials.com/instr...zel_howto.html
2. Upgrading the audio system: http://forums.corvetteforum.com/audi...-overhaul.html
http://forums.corvetteforum.com/audi...ress-pics.html
http://forums.corvetteforum.com/audi...o-install.html (Note: this one is for a C6, but most all of the info is relevant to the C5)
and a couple of "generic" ones not specific to Corvettes:
http://www.ehow.com/how_5829_wire-car-stereo.html
http://www.caraudiohelp.com/installation_video.html
3. Removing the door panels: http://www.vetteessentials.com/instr...or_handle.html
4. Removing the radio bezel and stock head unit:
http://forums.corvetteforum.com/c5-g...you-think.html
5. Grounding an aftermarket amp:
http://forums.corvetteforum.com/audi...nger-seat.html
http://forums.corvetteforum.com/c5-t...nnections.html
Hope the above threads help educate you on what you want to accomplish. Good luck.
The Lizzard
Old Aug 23, 2016 | 08:50 AM
thunder1951
4. Removing the radio bezel and stock head unit: 40. How to remove radio bezel and stock head unit:
The Lizzard
Can't thank you enough sir, I appreciate your help!
Old Aug 27, 2016 | 08:01 AM
thunder1951
I am still narrowing it down for my radio, does anyone have a suggestions as to which double din radios have a better viewing in sunlight? I know almost all are non viewable in sun light but maybe some one has an idea. I read somewhere about 3M non reflective material to cover the screen. I am looking at the Kenwood DNX773.
Old Aug 31, 2016 | 08:29 AM
thunder1951
Its getting close for my radio system but my wife says 3k is a lot to put into the car for sound and now it has me thinking harder about spending the 3k but all the old sound has to come out and decent equipment isnt cheap.
Old Aug 31, 2016 | 01:11 PM
LoneStarLizzard
If your C5 has a loud, or even medium loud exhaust tone, you'd be wasting your bucks installing a high quality system.
So rather springing for the high-end navigation head unit, subwoofer(s), speakers and amp, go for mid-priced ones. In any event, invest in vibration damping and sound deadening materials as the foundation to your system, and address the entire interior and the doors, not just the trunk/storage area. You'll at least eliminate most of the road noise.
Several of the threads I provided to you show-n-tell how to install all of this stuff yourself. Doing so will allow you to spend more on components while still keeping your bride happy. I estimate I spent about $2,500 in components and installation materials and $0 in installation labor, and got a reasonably high quality system. Also, doing your own install will teach you a lot about how your ride is put together, and will make troubleshooting (for any reason - seat issues, for example) less daunting.
The Lizzard
The Lizzard
Old Sep 1, 2016 | 08:15 AM
thunder1951
The Lizzard
The Lizzard
I agree with you that I can get more of the top end components by doing the labor myself and getting to know the inside skin of my car. I am semi retired and do IT work for a number of tax offices and custom build computers for a local company. I start prepping my tax offices in September so now my time is shorter than in previous months and knowing me it would take me a long time to replace my system top to bottom. I don't work as fast as I use to on my own projects. My C5 has nice mellow sound coming out of the magnaflow cat back system. So cabin noise is not very bad at all.
Old Sep 1, 2016 | 09:36 AM
73Corvette's Avatar
73Corvette
You could keep the stock HU and upgrade speakers... then later on upgrade the HU and then add an amp and sub if you want to...the speaker upgrade is a plug and play... and you can get an adaptor cable to make the factory head unit Bluetooth and Ipod capable... just sayin, there are less expensive alternatives... they are an improvement over stock...
Old Sep 4, 2016 | 06:36 PM
lebeeby's Avatar
lebeeby
Mine was less than that. Took the car to Dennis, and you are a LOT closer than I was. Not only did an excellent job and done right, he cleaned the car as well and stored it for me for 3 weeks while I was spending my son's inheritance. That is well above the above and beyond criteria. I cannot say enough good things about the work. Included all JL Audio speakers, 10" sub & box, amp, back up camera, front camera, Sirrius and the DDX9903S deck.
Old Sep 5, 2016 | 10:02 AM
thunder1951
I am looking forward to Dennis doing my install and thank you for the good words about Dennis and his company it makes me feel reassured to have a professional doing the install.
To Radio replacement
