Ordered New BOSCH SR8581N Starter
I would like to replace starter bolts when I do the job, but not sure if its necessary? Am I able to order bolts from amazon too? I wasn't able to find ones that fit my 2002 C5.
If all works out the way they say I should have my new starter tonight by 9pm?!
I will be shocked!!
Total price was like $123
I will order both.
I will be shocked!!
The Bosch unit appeared to me to be a high quality part. Like I said above no problems almost 6000 miles now and a year and a half.
Anyone get squeal with a new starter install? Did you shim it?
I've tried 2 starters now on my 2000 camaro with the same LS1 engine.
SUM-829200
Bosch SR8581N
Both squeal as if the starter teeth are engaging the flywheel for too long.
No stripped bolt holes
Torque to spec 37 ft/lbs.
I'm using a 168 tooth B&M flexplate 20304 which was working fine with the stock starter.
The only reason why I replaced the stock one is because I read that the truck starters with the longer bolt could save my block from cracking where the starter mounts.
It's not belts. Those were removed and the problem is there.
Has anyone used the 2 bolt truck starter with success with an aftermarket flywheel? What brand was used? No high pitched screech on startup?
I have a B&M 168 tooth flex plate (same as stock), so maybe the stock starter with one long bolt and one small bolt has the tolerances to handle any slight differences in my aftermarket flex plate while the BOSCH SR8581N and SUM-829200 does not. The starting position of the gear on the bendix has me wondering where the position of that gear is on these that use the long 2 bolts:
ACDELCO 3231637
ACDELCO 3361932A
ACDELCO 3231656
AC DELCO 3371115 uses 1 long and 1 short bolt, the stock replacement.
Stock on top, truck starter on bottom:
Stock LS1 starter:
Truck starter
The AC Delco truck starter in this last pic looks like the gear is pushed in a little more than the aftermarket ones I've seen. Still not tucked in like stock 4th gen fbody or Corvette OEM starters with the short bolt. I'm not sure how big of a difference this makes as the contact point on the flywheel when extended is what matters. I really need to get this on a lift and have someone start it while I look at the contact points. A little water based paint on the teeth of the starter gear should tell what is actually happening here. I wonder if the problem goes away with a stock flywheel with one of these truck starters lol.....
I checked the starters on the testing device at O'Reilly and they extended fully and spun without issue.
What did you end up doing? i have the EXACT same problem. My OEM starter (With finicky solenoid) makes zero noise. A brand new Bosch SR8581N squealed horrible on start, almost like it was grinding internally. tried shimming it and it got even worse. One time it did not even engage the ring gear just that high pitched grinding.
BTW this is on an LS3 with Monster 18lb Billet Steel Flywheel
I ended up buying an AC Delco 6.0 Escalade Starter for an 07 (i think) Part number 337-1033. It is about 1/2" shorter and has a smaller diameter body than the LS1/6 starters but it is still rated at 1.7kW. Put the part number because in all these threads no one ever does...
Bolted up perfect, solenoid in the exact same spot, runs perfectly no strange noises. The Bosch starter was just garbage and mustve been stripped internally or just sounds god awful. It wasnt grinding my flywheel that I could see but it sounded like it was grinding internally to the starter. Junk... only buying AC Delco starters from now on.
